Drag NHRA, IDRC, IHRA, NDRA
Whats the proper way of launching the Z?
Old Oct 26, 2007 | 07:33 PM
TheGest's Avatar
TheGest
Default Whats the proper way of launching the Z?
I got an 07Z and alot of time i try to launch it, the car goes sideways,
3.5k Rpm slowly let of the clutch?
Old Oct 26, 2007 | 07:35 PM
Nexx's Avatar
Nexx
quickly slowly left off the clutch.
Old Oct 26, 2007 | 07:39 PM
LT_350Z's Avatar
LT_350Z
3.5k? wow i do 2.5's and if i let go of the clutch a lil too fast i burn rubber!!!!! try to lower the rpms a lil and half engage the clutch
Old Oct 26, 2007 | 07:41 PM
TheGest's Avatar
TheGest
07 grip weird, you have an 07?
Old Oct 26, 2007 | 07:46 PM
_Fayte_'s Avatar
_Fayte_
3.5k is way too much man... I launch at 1k-1.5k, and REAL slowly let go of clutch
Old Oct 26, 2007 | 07:52 PM
LT_350Z's Avatar
LT_350Z
oh well i have an 06
Old Oct 26, 2007 | 07:56 PM
hidehide's Avatar
hidehide
Are you guys serious that letting the clutch slowly??
Its gonna burn the clutch..
Old Oct 26, 2007 | 08:02 PM
scottrocket's Avatar
scottrocket
i dunno about you guys, but i don't think you're gonna get too far "launching" from 1-1.5k other than a bog.....unless by launch he means a normal acceleration from a stop light or something. I'm a noob to driving a manual so i guess i shoudnt talk but any time i attempt a "launch" it's around 3-4k rpm and i usually slip the clutch just enough to keep traction in the rear but it's a fairly quick smooth clutch release....i dunno, i'm probably better at doing it than describing it...
Old Oct 26, 2007 | 08:13 PM
TheGest's Avatar
TheGest
yea i try launching around 3k but damn 1.5k what kind of launch is that
Old Oct 26, 2007 | 08:50 PM
Bottled Water's Avatar
Bottled Water
peg the rev limiter and drop it. no slip. just drop it.
Old Oct 26, 2007 | 11:47 PM
NISMO_558's Avatar
NISMO_558
I usually launch at 3k and have the clutch at almost the engagement point and then drop the clutch, and it grabs right off the bat
Old Oct 27, 2007 | 12:37 AM
VitViper's Avatar
VitViper
This thread == lol
Old Oct 27, 2007 | 02:50 AM
Z04's Avatar
Z04
let it hit redline, bounce there for a second or two, then dump the clutch.
Old Oct 27, 2007 | 03:53 AM
2TH PWR's Avatar
2TH PWR
OH man. hahaha.
On street tires launch just above idle. That is around 1800 rpm. It's not a HONDA! Let the clutch out nice and smooth and apply gas as you have traction. This should get you to 60 feet in 2.0 seconds or less.
Edit: I forgot turn off VDC or TCS if you have them.
Old Oct 27, 2007 | 09:32 AM
timmays350's Avatar
timmays350
helps if it's in 5th or 6th gear as well, saves shift time that 1st 2nd 3rd and 4th burn up
Old Oct 27, 2007 | 02:45 PM
TheGest's Avatar
TheGest
Originally Posted by 2TH PWR
OH man. hahaha.
sounds right
Old Oct 27, 2007 | 03:28 PM
henry j's Avatar
henry j
you launch at 1.5 so you dont sit there and burn rubber for no reason. i usually launch around 1.5-2 so i can get sum good speed and use the power that the Z has.
Old Oct 28, 2007 | 05:51 AM
rkemp1's Avatar
rkemp1
Come on man! why are you giving this guy such bad advice. To the OP if you wanna launch best put it in 7th gear and launch at 11000 RPM! That will keep you from spinning!!!
All joking aside this website may help... www.rangeracceleration.com. Its a Corvette but most of it translates to the Z. Warmmilk found the site to give proper credit.
Old Oct 28, 2007 | 08:20 AM
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
My best launch on street tires was by feathering the clutch with around 2500rpm to 2700rpm.
Hold your clutch right at the engagement point, then when your ready to launch feather out the clutch while pressing down on the gas pedal.
Hope this helps
Todd
Old Oct 28, 2007 | 01:32 PM
kleefton's Avatar
kleefton
2700-3000rpms work best.
1500rpms will yield too much bog and the best you'll get are 2.2-2.3 60' times. I don't think any of the guys that run 13s in their stock or near stock Zs are launching at 1500rpms. Well, maybe some of the 07' guys are, but 03-06 need to be closer to 3000rpms to run a good time.
