Drag NHRA, IDRC, IHRA, NDRA
Spining
Old Nov 26, 2007 | 11:11 AM
Originally Posted by Motormouth
this is a terrible thread.
and it's spinning is what people are insinuating, not spining or spinging or spooging.
listen it's simple:
your car should not be losing traction like this unless you are driving it over the limit of tire adhesion (or if you are Turbocharged or something). if you pop the clutch when you let off it will kill your traction, if your tires are bald it will kill your traction, if your alignment is off it will kill your traction.
TTD:
1 - check your alignment
2 - check your tire tread for improper wear or extreme wear
3 - learn how to launch your car and shift properly
/thread
Show us how its done here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html.
Old Nov 26, 2007 | 11:18 AM
Motormouth's Avatar
Motormouth
Originally Posted by phat04350z
Yes I am using the stock tires and it was around 40* out. When I shift I am not letting off the gas or powershifting. Maybe it was both combined. Like I said it wasnt till I was 1/2 way through 3rd gear I had grip again. My take off was perfect for driving a RWD car and no spin
correct me if I am wrong, but I thought powershifting is 'not lifting' when you are shifting... so not letting off the gas while actuating the clutch is powershifting?
Old Nov 26, 2007 | 11:19 AM
scotts300's Avatar
scotts300
Originally Posted by davidv
Precisely. https://my350z.com/forum/northern-california/315995-sacramento-drag-racing-test-n-tune-saturday-24-november.html
Old Nov 26, 2007 | 11:23 AM
Motormouth's Avatar
Motormouth
I haven't recorded a time since I was stock of 13.7-something more than a year ago. I am hoping to run my car next weekend and we will see but I need tires first.
also, I don't need to prove my abilities to give rudimentary knowledge on how to drive a car. nothing I said is disputable. these cars should NOT lose traction badly like that with stock power levels unless something is wrong. I think the OP is talking about driving aggressively on the street, not necissarily launching at the drag strip. a simple check over of his setup is nothing to debate.
Old Nov 26, 2007 | 12:03 PM
phat04350z's Avatar
phat04350z
i am stock and I am not trying to hit 11sec. I am trying to get a high 13 and hit it all the time. No point on adding power if you cant make a stock car run what its supposed to
Old Nov 26, 2007 | 12:07 PM
Motormouth's Avatar
Motormouth
I like that attitude
but yeah, my suggestion (not an expert) is to just check over the car as I listed to at least rule out mechanical issues first.
Old Nov 26, 2007 | 02:50 PM
coachk's Avatar
coachk
40 degree temps mean bad traction and lots of spining,spinging,spitting,spooking etc etc
Just keep practicing and you'll eventually get the feel for your car...
Old Nov 26, 2007 | 03:21 PM
phat04350z's Avatar
phat04350z
Yes I know practice just looking for any help... guess I gotta wait till spring now
Old Nov 26, 2007 | 05:09 PM
I wish I had that in front of me...
But I know that the 745 does run a low 14, and since from what I remember he was 1/2 car in front I was not far behind. I know if I didnt spin out through 2nd and some of 3rd I would have pulled ahead. Thats what lead me to my question of how to limit that spin or what you guys do.
I have my time slips for November 24 in front of me. The high was 50 degrees. 60 foot times are:
1.982
2.003
2.005
2.025
2.043
2.084
245 mm all-season tires.
Old Nov 29, 2007 | 08:19 AM
malized's Avatar
malized
guys , what do u think about a cusco diff 1.5 way or 2 way to have less spining ???
joe
Old Nov 29, 2007 | 09:05 AM
scotts300's Avatar
scotts300
joe
To reduce your, uh, spining, I'd suggest a set of drag radials given THE WAY you are driving. At your power, even a set of BFG DRs would do the trick. Lower the tire pressure, and off you go. If you really want a tire that works, go for the Mickey Thompson ET Street RADIAL. These are a streetable tire, and I've seen guys with 600rwhp make 1.5x 60's with them. Drive to the track on them, lower the tire pressure, run all day, raise the tire pressure, drive home.
Old Nov 29, 2007 | 09:10 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I do not have a time slip on me. I ran against a BMW 745i i think... From me spining by the end he was 1 car infront of me
Modulate throttle upon hitting next gear, apply gas as fast as possible but with no spin-def dont powershift. In other words you havwe to peddle it til you can put it to the floor. Its very easy in an NA Z, try it at 600whp in the cold lol...
Old Nov 29, 2007 | 03:25 PM
phat04350z's Avatar
phat04350z
Alberto I am sure you have more trouble then I have...lol
Old Nov 29, 2007 | 04:25 PM
Peak350's Avatar
Peak350
You need to lift when it starts to spin. Sometimes the track can be slick sometimes its just that you break the traction because you let the clutch out so fast. Regardless you need to lift until the tires catch THEN get back into the throttle more slowly.
Old Nov 29, 2007 | 06:52 PM
malized's Avatar
malized
Originally Posted by scotts300
Don't powershift? N/A Z33s can be kept from spinning with proper shifts. If you are drag racing, you need a better tire set-up, drop the pressure, then powershift.
drop the pressure for how much PSI for the rear ????
Old Nov 29, 2007 | 07:16 PM
Peak350's Avatar
Peak350
Don't drop the pressure on a street tire, only a drag tire does this technique work effectively.....thats the part of his post that might be unclear, so I figured I'd try to keep you from making that mistake (which I made a lot in the past).
Old Nov 29, 2007 | 08:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I drop to 27psi on street tires felt better traction and no loss in trap. Any lower is no good unless you run a DR...my opinion.
Old Nov 30, 2007 | 02:10 AM
  #38
malized's Avatar
malized
thx a lot man ...
Old Nov 30, 2007 | 02:11 AM
  #39
malized's Avatar
malized
+1
Old Dec 3, 2007 | 12:26 PM
  #40
malized's Avatar
malized
what is the best tire for drag street on + 550 bhp ??? and what about the GREARS... there is some risk on my STOCK gears box and stock diff ???
