Drag NHRA, IDRC, IHRA, NDRA
Burnout in water box
Old Mar 3, 2008 | 06:34 PM
  #41
DouBLeJ16's Avatar
DouBLeJ16
Originally Posted by Peak350
I launch at higher that that usually, its all in punishing the clutch (mind you, I plan on putting an aftermarket clutch in within another 10k miles so its of no consequence to me).
What kind of 60', 1/8th ET, 1/8th MPH are you running?
Old Mar 3, 2008 | 08:07 PM
  #42
Peak350's Avatar
Peak350
I've run a best of a 1.922 60' (stock tires) and usually pull consistent 1.93-1.95 times. When I slip out of my 1.9x rhythm I am usually pissed at myself. 330' I tend to hit between 5.5-5.6, the better the conditions the closer to the 5.5 mark I am. from the 330' to the 660' (1/8th) I'm consistently about another 3 seconds (so best of 8.5 to a consistent 8.6-8.7). Traps in the 1/8th (mind you I've never seen better than 800+ for a DA) are usually 80-81 MPH and HEAVILY dependent on conditions. They are only lower or higher if I do something extremely wrong on launch.
The key to the time is in the 330' time. After than most runs will be about the same, second gear has wound out by that point so its pretty much just grabbing 3rd around that mark and riding out almost the entire back 990 from there.
60' tells if you spun or not, 330' (given a good 60') tells how much the engine was bogged (or how much the clutch is slipping in some of my runs ) from the launch.
Old Mar 4, 2008 | 04:15 AM
  #43
DouBLeJ16's Avatar
DouBLeJ16
Good times.. I would of thought the 1/8th trap speed would be higher on a 2007, considering I've trapped 80mph in less than perfect conditions and I'm also in FL.
Old Mar 4, 2008 | 05:21 AM
  #44
Peak350's Avatar
Peak350
Veetec got 83 on his good run. He's getting ~ 3mph more out of the 1/8th. I dunno if the trap speed at gainesville reads low (doubtful, I ran a week ago and they'd just reconnected and re-calibrated the timing system) or if its something with how I'm driving or what, but my times (1/8th mile) are the fastest I've seen for stock, I'm getting beat in the back half (because of the trap speed). I think that all comes down to me seeing ~70 degree weather and others seeing 35-45 degree weather.
Old Mar 4, 2008 | 06:21 AM
  #45
ajcool2's Avatar
ajcool2
Originally Posted by skr00ball
He apparently was speaking to the civic crowd
I thought he was joking at first.
Old Mar 14, 2008 | 10:25 AM
  #46
DouBLeJ16's Avatar
DouBLeJ16
I hear ya man, that 70degree weather blows. I can't even touch the top of my engine for more than 2 seconds after running a few times, burning hot.
Old Sep 25, 2008 | 08:16 AM
  #47
tylerxfire's Avatar
tylerxfire
some people really need to do research before commenting on things, especially if it is gonna send people in the wrong direction, whole beginning of this thread is garbage, e-brake are you kidding, and that it only cuts power on auto's, come on. don't give people garbage that is untrue.
Old Sep 29, 2009 | 09:39 AM
  #48
DouBLeJ16's Avatar
DouBLeJ16
I just found a video of my run that I put up on youtube a few years ago:
http://www.youtube.com/watch?v=3RoCAWNzH7E
Old Sep 29, 2009 | 10:16 AM
  #49
03threefiftyz's Avatar
03threefiftyz
What were your intervals? I have been in the 8.55-8.60 (ideally I would like to get into the 8.35-8.40 area) range this fall in the 1/8 with traps b/w 83-84mph.
You don't need to do a burnout on street tires.........just give a quick spin to get the water and debris off. You have to pull the brake light fuse to do a "real" burnout in our cars.
Old Sep 29, 2009 | 03:54 PM
  #50
ajcool2's Avatar
ajcool2
Yup Like this.
http://www.youtube.com/watch?v=Atu-91jFz6c
Old Sep 29, 2009 | 10:47 PM
  #51
fowlman01's Avatar
fowlman01
Originally Posted by ajcool2
that's the way I do it.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
