Drag NHRA, IDRC, IHRA, NDRA
Burnout in water box
Old Feb 28, 2008 | 08:31 AM
DouBLeJ16's Avatar
DouBLeJ16
Default Burnout in water box
Well, I'm on NT555 street tires so I'm not looking for a crazy smokey burnout, but I would like to clean them off a little more than I'm currently doing.
The car spins just a little in 1st, then hooks and trys to start going (or at least creeps forward a little).. I can never just sit there and spin.
I heard taking out a fuse can fix this.. I guess it disabled your rear brakes so you can just stomp on the brakes while spinning..
Any more info about it? I searched and couldn't find anything. What fuse is it? Anyone have a picture?
BTW, I'll make sure to put the fuse back in before I leave the track, this is only for when I'm running.
Thanks in advance for any help
Old Feb 28, 2008 | 10:40 AM
Skorch's Avatar
Skorch
Have you tried using your e-brake?
Old Feb 28, 2008 | 10:48 AM
SteevoZ's Avatar
SteevoZ
E-brake!!!??? WHAT? The e-brake stops the rear wheels.
There is a fuse that disables the brake lights which also disables the limiting of the throttle during braking. This way you can use the brakes just enough to hold the front wheels and let the rears spin while giving it all the throttle you want.
Old Feb 28, 2008 | 10:50 AM
SuperBlack350z's Avatar
SuperBlack350z
you don't have VDC so i don't think that fuse thing would work on your car.
Are you doing a burn out correctly?
Try this...
rev to 3k, dump the clutch and the switch your clutch pedal foot over to the brake pedal and hold down while pressing the gas pedal. So your car can stay in one place while doign a burn out.
Old Feb 28, 2008 | 10:57 AM
SteevoZ's Avatar
SteevoZ
^^Base models still have throttle limiting when the brake lights go on.
What you need to do it pull the fuse for the 3rd brake light (i think its just that one) and then do as SuperBlack350z said, holding the brakes just enough to keep the fronts in place while still allowing the rears to spin.
EDIT: Base models also do not have a LSD which means you'll mostly have one wheel spinning and the other staying still.
Old Feb 28, 2008 | 10:58 AM
skr00ball's Avatar
skr00ball
He apparently was speaking to the civic crowd
Old Feb 28, 2008 | 11:06 AM
blktrack350's Avatar
blktrack350
well if you are on street tires you dont need a monster burnout. and you shouldent be going threw the water.
Old Feb 28, 2008 | 11:16 AM
NismoZ350's Avatar
NismoZ350
SO you're trying to clean your tires by doing a burnout? Have I been missing something? (serious)
Old Feb 28, 2008 | 11:17 AM
The brake light fuse thing is for an automatic transmission. If you hit the gas and clutch hard, the tires will spin forever. Its difficult to sit in one spot because the rear end will want to come around. It doesn't take much to clean off street tires.
BTW where are the time slips?
Old Feb 28, 2008 | 11:47 AM
DouBLeJ16's Avatar
DouBLeJ16
Dear Skorch,
I just ruined my brakes. Thank you.
haha.. just kidding. The e-brake trick worked with my scion tc, but not the Z.
Old Feb 28, 2008 | 11:52 AM
cmart350's Avatar
cmart350
Unless you are on drag slicks just rev it up and pop the clutch for a quick little clean off of the tires (pebbles, rocks, etc.) and don't go through the water. Don't know why you'd need to do any more then that.
Old Feb 28, 2008 | 11:54 AM
DouBLeJ16's Avatar
DouBLeJ16
Originally Posted by davidv
The brake light fuse thing is for an automatic transmission. If you hit the gas and clutch hard, the tires will spin forever. Its difficult to sit in one sport because the rear end will want to come around. It doesn't take much to clean off street tires.
Are you sure it's only for automatic's? I've seen alot of manual owners talking about it here in the past.
Also, I have no time slips worth posting.. At least nothing that would make it onto the list, considering I'd be placed in the modified catagory with my popcharger. I ran some horrible times in the 1/8th mile on saturday because it was so nasty humid out, I think my best was a 9.34 @ 77mph.. very weak 60', MPH was 3 lower than normal.
Out at this track there is alot of dirt/shells/crap laying on the ground, when you get in line your tires get very dirty. The moron's that operate the track spray water all the way across the entire lane so you have to roll through it, there is no going around like at bradenton. I usually go through it kind of fast, sit about 2 feet in front of the water and start "trying" to do a burnout.. It usually spins for 2 seconds then starts moving forward.
I haven't been hitting the brake at all when doing a burnout because I always thought you had to do the fuse trick to not mess anything up.
Old Feb 28, 2008 | 11:55 AM
DouBLeJ16's Avatar
DouBLeJ16
Because 90% of the time I can't go around the water. They really need to work on their water spraying skills. I'm just trying to burn the water off/clean them.
Old Feb 28, 2008 | 12:09 PM
Yes. The automatic transmission will not let you “power brake” or “torque brake.” That is braking and giving the car gas in drive. Automatic racers will give you a better description.
As you mentioned, at some dragstrips its impossible to go around the water.
Old Feb 28, 2008 | 01:17 PM
SteevoZ's Avatar
SteevoZ
In manuals, power is cut by 30% when both brake and gas are pressed at the same time. If thats not the same as in the automatics its a similar concept and does make it harder to power brake.
Old Feb 28, 2008 | 02:43 PM
coachk's Avatar
coachk
I respectfully disagree...I have never pulled my brake fuse. I did notice you said braking and giving the car gas in DRIVE. I've only done burnouts in manual mode and have not had any problems. Never tried to do the burnout in drive.
Old Feb 28, 2008 | 05:46 PM
At the starting line you have one foot on the brake, and with the other foot you are picking up the RPM. The transmission is in gear. Is that correct?
Old Feb 28, 2008 | 05:56 PM
Get_Zwole's Avatar
Get_Zwole
it cuts power even in a manual. When i first got the car i dumped at around 4 k got up to 5k and was on the brake and gas and i ended up killing it it just fell on its face. gonna have to pull the fuse or throw a fit that they are idiots spraying the water.
Old Feb 28, 2008 | 06:06 PM
I see no reason why with a manual transmission you would be on the gas and brakes with the transmission in gear. Fill me in.
Are you confusing “cutting the power” with the torque converter simply reaching the stall RPM?
Old Feb 28, 2008 | 06:14 PM
SteevoZ's Avatar
SteevoZ
^^ long stand still burnouts.. not sure about drifting but i'm sure some people use this as a technique in drifting.
