Drag NHRA, IDRC, IHRA, NDRA
Please enter your quarter mile times here!
Old Sep 11, 2003 | 08:10 AM
  #61
03redlineZ's Avatar
03redlineZ
I ran a 14.290@100 stock on a day at 88 degrees very very hot and humid like 100 percent humidity.
Old Sep 11, 2003 | 06:46 PM
  #62
myinfinitig20's Avatar
myinfinitig20
my times are in my sig
Old Sep 13, 2003 | 07:02 PM
  #63
ZpEeDRaCeR's Avatar
ZpEeDRaCeR
idk, if anyone is still reading this post ... but for fun i used my tazzo and ran a 1/4 mi in the street inbetween two long red lights at 14.94 @ 99mph
Old Sep 13, 2003 | 07:51 PM
  #64
jackie chan's Avatar
jackie chan
take it to the track and get some real times...those dont do your car justice
Old Sep 17, 2003 | 02:49 PM
  #65
Blownaway's Avatar
Blownaway
Satrting to get better. Now with a 55 wet shot
ran last night at GLD on 19s again
R/T .696
60 2.098
330 5.797
1/8 8.802
mph 82.59
1000 11.391
1/4 13.562
mph 104.03
Old Sep 20, 2003 | 02:11 PM
  #66
daking350's Avatar
daking350
Best 1/4 12.8 @ 104 w/2.08 60 ft
Best trap 108
Best r/t .508
Best 60 ft- 1.88
ON THE BOTTLE!!!
Old Sep 20, 2003 | 02:41 PM
  #67
Blownaway's Avatar
Blownaway
got a time slip for that run, would love to see what I am doing wrong for you to be running 12.8s at 104
most times I have seen on the low 13s were a 13.1@106 so how you are running 12s with trap under 108-109 is puzzling?
Old Sep 20, 2003 | 03:02 PM
  #68
daking350's Avatar
daking350
First off, Drag radials or slicks are a MUST..Burn out and get them hot and stickey.(make sure you pull the brakelight fuse out or the sec ond you touch the brake the car will stall)
Its all in the launch, find a nice rpm like around3300,dump the clutch and hook before you mash ther pedal to the floor because if you mash to soon when the N2O kicks in you will spin through all 3 gears.
the 12.8 i ran was during bracket racing and i mashed the brake at theend but still busted out of a dialed in 13.25...I did pull a 1.8 60ft time once and was wll on my way to a 12.5 but missed 3rd gear double clutched and ran 13.1 @106...Practice the launch and launch on juice!!
Old Sep 20, 2003 | 04:15 PM
  #69
jackie chan
yeah i was looking at it and thought you got out of it. now get a full run in
Old Sep 20, 2003 | 06:04 PM
  #70
daking350's Avatar
daking350
Well remember trap speed is secondary when you make up almost 3-4 tenths on the 60ft due to traction. Also keep in mind that the dragradials are a larger diameter than the stock 18" thus causing a lower trap speed. I normally trap around 106-108mph but like I said on that particular run
i slammed on the brakes at the end, otherwise I would have run a 12.5-6..Also remember a trap speed is an average speed over a certain distance(not sure how many)
Old Sep 21, 2003 | 09:33 AM
  #71
2003z's Avatar
2003z
Old Sep 21, 2003 | 09:38 AM
  #72
jackie chan
Originally posted by 2003z
13.861
slip...did you use the M/Ts?
Old Sep 21, 2003 | 09:49 AM
  #73
2003z's Avatar
2003z
dont have the slip, I'm out of town now, but yes, with the M/Ts. dropped my 60' by about .5-.6 sec between the tires and borla.
Old Sep 21, 2003 | 10:43 AM
  #74
jackie chan
fun? if you have any more qs pm me
Old Sep 26, 2003 | 07:41 AM
  #75
supirio's Avatar
supirio
Default Atco Last night
Nismo exhaust only, regular tire pressure, full spare, my fat ***, etc etc:
r/t .216 .530 .352 .160
60' 2.376 2.258 2.715 2.301
330 6.408 6.250 6.968 6.397
1/8 9.679 9.507 10.251 9.642
mph 76.25 76.67 76.17 76.84
990 12.353 12.166 12.930 12.304
1/4 14.748 14.549 15.334 14.696
mph 97.01 97.36 98.15 98.66
temp: 72
humidity: 88
This was first time at the drag strip, was a lot of fun, even though my times sucked =)
Old Sep 27, 2003 | 03:22 AM
  #76
mjedens's Avatar
mjedens
Default Friday Night
Disconnected front sway bars - don't know if this helped much! Was hoping for better weight transfer! This is only a 1/8 th mile track- no 1/4 within a 100 miles!!
1/8 = 7.59
60 ft = 1.67
mph = 89.96
16" MT, a lot of ZEX N20, & all available bolt-ons!!
Old Sep 28, 2003 | 09:41 PM
  #77
Nano's Avatar
Nano
60ft - 2.178
1/8 - 9.076
ET - 13.965 @ 102.189
Bone stock
Old Oct 3, 2003 | 04:39 PM
  #78
fowlman01's Avatar
fowlman01
Weds night at Infinion
14.332 @97.95
14.322@98.13
14.462@98.43
wheel spin all through 1st gear and part of second.
started from an idle. T/C off manually shifted at redline
Old Oct 5, 2003 | 03:01 PM
  #79
Toronto350Z's Avatar
Toronto350Z
14.045 @ 101 mph
13.955 @102 mph.
2600rpm launch + power shifting.
My car was in stock form at that time. No mod.
Old Oct 5, 2003 | 04:28 PM
  #80
Anthony Mantovani's Avatar
Anthony Mantovani
R/T- .101
60 ft- 2.143
1/8- 9.238
1/8 mph- 78.79
1/4- 14.203
1/4 mph- 101.58
This was my first time at the track. I got only 3 runs this was my best. My other 2 runs were 14.3 at 99mph
