The air was very good tonight, but my clutch wasn't.......results....
I am getting very fustrated with this replacement slave cylinder. If I rev the rpms where I need to now, I lose hold of the higher gears, during the runs.
If I bog the launch, I lose too much on the bottom end. If I don't do enough of a burn out, it will spin too easy, but at least then, the higher gears hold.
On the whole, I wasn't too upset, as I wasn't sure if the clutch would hold at all, after last week. Still, great air, and the car was running so strong, as was observed on my very first pass, where I spun off the line, and going into second, and still ran a 13.2. From there, the stress of lanching took its toll, and I could only get marginal hold when upshifting after hard launches. I took some of the stress off on my best pass by lifting ever so slightly longer than normally. The passes were few as well, due to several cars breaking on the track. Normally the car gets about 1 mph faster on the second run, if I can run back to back, but tonight, that didn't happen, and the clutch probably would have slipped worse.
I think I am done with Carolina Dragway for a while. I may have to get a new clutch, or make one more try at one of the faster tracks soon.
On a good note, I challenged a guy with a new 2008 C6 Corvette 6 speed. I know they are much faster, but thought I may be able to tree him, and get off the line better. I did, and beat him by half a car, although he was coming back strong, and trapped 110.94 to my 105.25. At a faster track, I am sure he would have trapped in the 112-114 range.
Anywho, here is my best slip, out of 6 passes.
but yea C5's usually trap 109-110 stock... and C5 Z06\s trap 113+ stock( on the low side)
But it really doesn't matter. I mean, THAT C5 could only trap 5mph more than HIS 350z at the same track and on the same day. That's all I was trying to point out.
As far as the 350Z goes Veetec is a great driver but he is also not the only one to trap at least 105 in a 350Z now.... that should just be considered par for the course IMHO.
FWIW the LS3 has pulled off 118~119mph traps... the old LS6 Z06 used to trap 118 on the upper end... He didn't say that was normal..but it does happen.
I don't get what you are trying to say? C5 is an LS1 with ~350hp in a 32xxlb car and they tend to trap 108~110mph... a C6 (400hp and similar weight) under 112mph isn't running near it's potential period..not the tracks fault just the drivers.
...Last edited by C5_vette; Nov 1, 2008 at 04:15 PM.
Anything can happen at the strip. Seen many a car (vettes included) where the driver is incapable of driving the car anywhere near its limits.
Not that it takes anything away from Veetec what-so-ever.
