Drag NHRA, IDRC, IHRA, NDRA
Wow drag racing is hard!
Old Nov 21, 2008 | 05:53 AM
  #41
S8ER95Z's Avatar
S8ER95Z
Wasting your time manually shifting without an aftermarket valvebody... you might think you are doing something but the 'delay' you are talking about are just shift points... it does that with or without your help.
Old Nov 21, 2008 | 07:43 AM
  #42
fowlman01's Avatar
fowlman01
5AT Z's run about a 1/2 second slower if left in drive.
Old Nov 21, 2008 | 08:00 AM
  #43
ajcool2's Avatar
ajcool2
Ive never raced with my Z left in drive because I dont like wasting runs so I cant say if it does or doesnt. I have done it on the street and theres a big difference but thats another story. I do know my maxima runs slower when I leave it in drive.
Old Nov 21, 2008 | 10:12 AM
  #44
S8ER95Z's Avatar
S8ER95Z
Hmm.. must be something really strange with the trans setup then.. Never seen an automatic (save for paddle shift setups) that did anything but hit the rev limiter when manually shifted. I could very well be wrong...
half a second seems VERY hard to swallow unless something magical happens in D that doesn't happen in any other gear.
Old Nov 21, 2008 | 12:09 PM
  #45
fowlman01's Avatar
fowlman01
Well swallow it, cuz that is what they turn in drive. I have a 5AT with a couple hundred runs on it. Most of it when it was stock. In manual mode I could chirp the tires in third. That is never going to happen in drive. It ran 13.7-13.9's on a regular basis. In drive it would be mid 14's. I have tried it, I have seen other people try it....it's just the way it is. My tranny had absolutely no hesitation when shifted manually until I put the vortech on it. Now it shifts slow as hell even with an aftermarket vb.
When stock it will hit the rev limiter when manually shifted if you are a crappy driver and don't know enough to shift 300 rpms short of redline. The 5AT is a hot setup for drag/bracket racing.
I don't know what kind of AT you have shifted manually, but there is no reason to hit the rev limiter with a 350Z 5AT unless it is F/I and the tranny is stock.
Old Nov 21, 2008 | 12:26 PM
  #46
ajcool2's Avatar
ajcool2
Thanks now I dont have to try it.
Old Nov 21, 2008 | 01:56 PM
  #47
S8ER95Z's Avatar
S8ER95Z
I've pretty much tried it in every car I've ever driven.... as I said I've never drive the 350Zs auto so you must be right.
Just knowing that a manual valvebody shifts on demand and a stock valvebody shifts when the ECM tells it too.. If you were really doing something usefull shifting why would you need to shift 300rpms ahead of where it shifts unless it was going to shift there anyways?
Old Nov 21, 2008 | 04:14 PM
  #48
fowlman01's Avatar
fowlman01
In manual mode the tranny will allow the rpms to go up until they bounce off the rev limiter, it stays locked into whatever gear you have selected and will not shift. While the 5AT shifts very quickly (faster than most 6MT's) it climbs up about 300 rpm's during the shift. If you shift at redline you will hit the rev limiter hence shifting slightly before. Go to a dealer and try an auto in manual mode and it will become very clear. The only time the tranny will shift out of a gear in manual mode is when it downshifts because you are going too slow for the gear you are in. ie. trying to stay in 5th while going 20mph, it will automatically shift down. When accelerating it is going to stay in whatever gear you put it in until it blows up or you take your foot off the accelerator.
Old Nov 21, 2008 | 06:35 PM
  #49
S8ER95Z's Avatar
S8ER95Z
Very impressive.. that would be the first trans that Ive heard of that behaves like that... I might just have to try one out for a spin.
Old Nov 21, 2008 | 08:31 PM
  #50
ajcool2's Avatar
ajcool2
Its actually pretty fun. I shift my car around the city alot now that I have my exhaust on and like to hear it down shift. I also love passing people in 3rd.
Old Nov 22, 2008 | 05:32 PM
  #51
fowlman01's Avatar
fowlman01
I have 3:55 gears so enjoy 3rd too.
you have a good range of speed in 3rd and it is punchy as hell. I use to go through the finish line in the quarter still in 3rd, so it is good for 100 or so with the stock rear end gears.
Old Jun 26, 2009 | 05:42 AM
  #52
str8dum1's Avatar
str8dum1
Well, 1st night back at the track with my new clutch. I got in 16 passes in about 3 hrs (like 12 in the 1st hour )but couldnt nail any of them Either I bogged off the line, spun my tires, or wheelhopped real bad 1/2 way down. General UHP 275 street tires at 29psi hot.
Granted it was 101 temp on the dash with my AITs ranging from 112 to 120 degrees (before my methanol).
Argh. It gets up good the 2nd half but 2.2-2.4 60's are no good.
best for the night was a 8.64 @88. My best is 8.46 @89.
The new clutch slips ok on the street but on the track, I am having a hard time modulating it enough, where i dont bog or dont sit at the line spinning.
There were a few ImportNC guys out there and by chance i got lined up with this nice Z. Pretty sure he beat me on that pass but I trapped like 12 mph faster
Old Jun 26, 2009 | 09:53 AM
  #53
I think you are getting it. Still looking forward to some quarter mile times.
Old Jul 24, 2009 | 11:50 AM
  #54
str8dum1's Avatar
str8dum1
Well ordered my 28" drag radials today. Line locks go on today. Got my mini-trailer to haul them, my jack, and a pump to the strip as well.
Hopefully better 1/8th mile in the next month. Then I might make the 100 mile drive to the closest 1/4 mile.
Old Jul 26, 2009 | 02:48 PM
  #55
str8dum1's Avatar
str8dum1
So i got my line locks installed and wired up. Using the horn button as the switch to activate. Some pics and video of how it works...
Thanks rpm06g35 for the part #'s
Some reason the video is not embedding so here is the Youtube link
http://www.youtube.com/watch?v=c5NtdIEeLyE
Old Jul 27, 2009 | 06:42 AM
  #56
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by JETPILOT
Hahahahaha!!!
You should try road racing. If you think drag racing is hard your in for a suprise!
Completely different skillset.
I know awesome road race guys who cant hit 13's in mod'd NA Z's and good drag guys who dont ever hit a corner hard.
Just because you can drive around corners doesnt mean you can be FAST straight
The differences at a drag strip between an awesome driver and avg can be almost 1 second down a measly 1320ft, that differences can be seconds around a course, same damage given the distance.
Old Aug 10, 2009 | 06:31 PM
  #57
str8dum1's Avatar
str8dum1
Well got my 28" tires in. Gotta get them mounted this week and hopefully to the track within the next few weeks to try them out. Also, got my trailer put together, just need to do the floor and the G will be ready to tow my tires/jack/and pump.
Old Aug 11, 2009 | 04:33 AM
  #58
denchan350gt's Avatar
denchan350gt
Nice!! Why don't you go to Freaky Fridays at the Fayettville dragstrip it's closer than the rock, kinston or jacksonville.
I think they run from 7pm-1am or later so it will be cooler. Just check their schedule for the next one.
Old Aug 11, 2009 | 07:07 AM
  #59
str8dum1's Avatar
str8dum1
Fayetteville is only an 1/8th mile. Dunn Benson is closer for an 1/8th mile. Have to drive to Kinston,Jax, or the Rock for 1/4mile, all ~100 miles each way.
Old Aug 11, 2009 | 10:38 AM
  #60
Coach@UPR's Avatar
Coach@UPR
Former Vendor
I think you're going to have a hard time fitting your G on that trailer. How far is it to the 1/8 mile track that you're going to run at? I have driven numerous times to the track which is 100 miles each way, with my DR's on. Just have to hope it doesn't rain hard.
Just joking about the trailer comment
