Drag NHRA, IDRC, IHRA, NDRA
launch RPM
Old Oct 5, 2003 | 04:19 AM
mrice's Avatar
mrice
Default launch RPM
What is the best RPM, and dump the clutch or feather?
Old Oct 6, 2003 | 05:45 AM
350_Z's Avatar
350_Z
Somewhere between 2500 and 3500 with feathering seems to get the best results.
Old Oct 6, 2003 | 11:48 AM
LaPuLaPu's Avatar
LaPuLaPu
Can one of you explain the technique of feathering? I've read a posting of a Z launching at 4K with feathering.... TIA
Old Oct 6, 2003 | 03:04 PM
infidsg35's Avatar
infidsg35
Well I just practiced a lil bit of launching and when I launched at 3000k and feathered the clutch WOW did my clutch burn up!! It stunk in my car.. BUT.. I launched pretty good and NO wheel spin.. Is it that bad to abuse you clutch like this every once and a while??
Old Oct 6, 2003 | 05:46 PM
themyst's Avatar
themyst
3000 rpm feathering out the clutch works best for me. I got my best 60 ft doing that. WIth the Z, no wheel spin = good. Little wheel spin = bad.
Old Oct 7, 2003 | 05:49 AM
350_Z's Avatar
350_Z
Feathering is just not letting the clutch all the way out, more like a controlled release while holding the rpms up. Dropping the clutch is just a quick release. To Feather I usually let the clutch out half way and then use a quick controlled release the rest of the way. Once all the way out I quickly push the gas all the way down, but don't slam it or you will get wheel hop.
Old Oct 8, 2003 | 05:47 PM
Turcoupe's Avatar
Turcoupe
Are you guys doing this with VDC on or off?
Old Oct 12, 2003 | 04:15 PM
keiffer953's Avatar
keiffer953
good question.....answer please.
Old Oct 12, 2003 | 08:24 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
OFF
Old Oct 14, 2003 | 06:31 PM
alex100's Avatar
alex100
when i launched at the track i'd rev it to 3 grand, keep the needle there, when the light hit that third yellow i dropped the clutch then floored it... that gave me my best time of the day... alot of my other runs i messed up :P yeah.. i'm a newb :P
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Calinismo350z
Sep 14, 2015 04:04 PM
