Drag NHRA, IDRC, IHRA, NDRA
Front Sway bar
Old Oct 20, 2009 | 07:53 PM
OldManZ350's Avatar
OldManZ350
Originally Posted by Nizmo0395
Took my sway bar off my Nismo. Memphis motor sports park test,tune tonight.
Sway bar total weight was 18.5 lbs.Temp should be around low 60's - mid 50's by the time the nights over. Close to when i posted my best time of 13.4.
I'll post results tonight or early tomorow am.
What is it like under normal street driving?
Old Oct 20, 2009 | 08:24 PM
03threefiftyz's Avatar
03threefiftyz
--->+1 for results.
Old Oct 20, 2009 | 09:08 PM
Nizmo0395's Avatar
Nizmo0395
It's like driving a minie van instead of my Nismo. First car i did this with was a 93 mustang lx, you get comfortable with the sway bar off and learn it's limitations. It's not that bad.
Old Oct 20, 2009 | 09:09 PM
03threefiftyz
Did you run today?
Old Oct 20, 2009 | 09:51 PM
Nizmo0395's Avatar
Nizmo0395
--->+1 for results.
Weight does transfer, just could'nt get Faulkin 615's to hook. Could not get rid of wheel hop did not want to break a half shaft so let off every time.
My advice to anyone that is interested would be to try it your self, it's like any mod. it takes time to get use to. Like launching,it takes practice, its another tool to use.
Posting best time and todays time. Only thing that improved was my trap speed by almost 2 mph. 1.8 to be exact. must be my $69 mod that did it! LOL
I'm lucky #13
Old Oct 20, 2009 | 09:54 PM
03threefiftyz
I might give it a shot on Fri.....not sure if I'll have time to get the front bar off by then, but we'll see. I just want a 1.80 60'. That and temps in the 40-50 range should give me the number I want. Thanks for giving it a run.
What mods on your nismo?
Old Oct 21, 2009 | 07:06 AM
Nizmo0395's Avatar
Nizmo0395
What mods on your nismo?[/QUOTE]
K&N filter inserts,1995 Cobra R wheels 17X9 with Faulkin 615's 275/40/17.
Took rear muffler off and had a pipe with tip welded and then bolted to original exhaust.Pipes coming of today sounds bad a$$ but to loud!
Good luck on friday if you get a chance, not that hard to remove.
Old Oct 26, 2009 | 11:04 AM
Cripplegto's Avatar
Cripplegto
Havent had a chance to run at the track the weather here is horrible, but i have to agree with nismo, its been like a week and a half and i love it driving with it off, it takes some gettin used to for those who like corners, but for me its perfect, since i have to be careful running DR's on a daily basis
Old Nov 5, 2009 | 08:03 PM
Cripplegto's Avatar
Cripplegto
I went to the track today and i have to say doing this was a good idea. My average 60' was a 1.889. I am very pleased and i highly recommend the removal of the sway bar
Old Nov 7, 2009 | 07:50 AM
Peak350's Avatar
Peak350
What track do you run at and what kind of times did you get?
Old Nov 7, 2009 | 08:03 AM
Cripplegto's Avatar
Cripplegto
BMP in bradenton, FL. Here are the slips
Old Nov 9, 2009 | 01:56 PM
scotts300's Avatar
scotts300
Removing the sway bar is a bit more (unnecessary) work compared to simply removing one bolt from each endlink to disconnect it from the bar itself. It takes like 5 minutes per side, including wheel removal.
Old Nov 15, 2009 | 07:37 AM
Nizmo0395's Avatar
Nizmo0395
Removing the bar and end links also removes 18.5 pounds from the front end which is a plus for the time.Took me a total of 1 hr. well worth the time when your talking drag racing and tenths.
Old Nov 15, 2009 | 11:50 AM
shwepser's Avatar
shwepser
hey guys went on track wednesday. my third time .i have a question ,why my speed at finish line are higher than everyone else .
look at my timeslips and tell me if im doing everything right ,
mods are HKS Hi power ,injen Cai , berk hfc ,08 base , stock wheels and tires(that what kills my time i guess)
my 60 feet time is 2.2-2.3 so if i get better tires launch better .ill shave those 0.4 off my time .means that im gonna run 13.0 or under 13.0?
Old Nov 15, 2009 | 12:00 PM
03threefiftyz
You have an HR........we have DE's, but your mph seems awfully high even still. Almost 86mph in the 1/8th is pretty nuts. What was the weather like?
Old Nov 15, 2009 | 12:29 PM
shwepser's Avatar
shwepser
in the mid70s to high 60s
Old Nov 15, 2009 | 01:29 PM
03threefiftyz
Given those conditions those traps are high, but not outside the realm of possibility.
Old Nov 15, 2009 | 03:52 PM
  #38
redline06's Avatar
redline06
jubus those are good traps , ur prob just driving ur car well. veetec was getting 109 traps stock so i dont see why it wouldnt be possible with mods. very good driving , just improve ur 60 foot and you should get into 12s easily
Old Nov 15, 2009 | 06:15 PM
  #39
terrasmak's Avatar
Better yet , just remove one endlink.
Obadabot
Jun 18, 2023 11:31 PM
