Who has the fastest all motor VQ35?
It's all right here
https://my350z.com/forum/3035907-post5.html
And Here for Hr's
https://my350z.com/forum/3035915-post6.html
And Here for Hr's
Yeah, I saw that. Didn't think that 12.3 was gonna be the fastest though.
I now know what I have to beat!
Car won't be a 350z though.
Are there any other cars with a VQ35 that are faster than 12.3?
Yeah no 11 sec max's yet. Getting close though.
My setup is gonna be a 2 door B13 sentra that will be gutted to all hell.
Gonna have a stock displacement VQ35 with around 12-13:1 compression, ported heads, and some big cams. Also the car is mostly likely gonna be an auto too.
Anyone know any places that custom grind VQ35 cams?
Aiming for low 11s all motor. The car should make a little over 300whp.
Then I might spray it to run 10s.
Why would you even look here knowing that the Z has easily half a ton on a gutted sentra? Of course you're going to beat those times with that power/weight..
That's like comparing a CRV with a B20 to a gutted EG hatch with a B20.. Might as well go ahead and check times on Murano's and FX's while you're at it.. (sorry in a sarcastic mood today) I love the older sentras and wanted to build one for awhile cept with an SR because it's just not the same without FI..
Already looked at that, thanks for your help man
Because not that many people run the VQ engine? Just researching right now.
You guys need to take it easy. I'm not talking **** about 350z's. I was just expecting them to be in the 11s. I know they are not the lightest car ever lol.
http://library.thinkquest.org/CR0215...second_law.htm
Acceleration = force divided by mass
You have less mass and the same force then you have more acceleration (I was/am a science geek)
+1 on what ni$mo350 said.
I'm interested in seeing how you go about achieving your goals, though. As you decide on more things and your plan becomes more concrete, let us know of your progress.
BTW, AudibleMayhem ran that 12.338 in a gutted and built block Z. I believe he could've ran faster, too, but changed his set up before he could get back out to the strip.
Alright cool man.
This won't happen for awhile I am just in the planning stages.
I might actually end up using a 6 speed tranny though. Through some further research I have found that it is pretty hard to get the autos to shift above their factory redline.
More info about the swap:
Chassis:
B13 sentra coupe (one seat, pedals, shifter, and a tach lol)
Engine:
02-03 maxima VQ35
Wiseco 95.5mm 11:1 pistons
Stock rods
Ported heads
Brian Crower stage 3 cams
Might try to fabricate some ITBs utilizing hayabusa throttle bodies
Custom long tube headers to a 3" exhaust
Megasquirt EMS running an EDIS-6 ignition
Transmission:
B15 sentra spec V 6 speed
Maxima bellhousing
Wheels/Tires:
13" Lenso VPD drag wheels
24.5x9-13 MT ET Drags
Mounting the engine/trans:
I will use a VQ30 maxima crossmember shortened 3" to fit the factory crossmember mounting points. This will allow me to use the stock front and rear engine mounts. The transmission will use the stock tranny mount. The only mount that will need to be fabbed is the timing cover mount. Then I'll be able to use spec v axles. I might have to run the B15 hubs though. That would not allow me to run the wheels I chose ^. Have to figure that out.
I got the idea to do this whole thing because of this guy. Small car with a V6 running ITBs. He is using a much more expensive engine management system though. Car sounds sick!!!
http://www.youtube.com/watch?v=LkFskOhVxNk
Chassis:
Engine:
02-03 maxima VQ35
Stock rods
Ported heads
Transmission:
Maxima bellhousing
Wheels/Tires:
