Drag NHRA, IDRC, IHRA, NDRA
Drag radials
Old Jul 28, 2010 | 03:19 PM
OSIRIS06's Avatar
OSIRIS06
Default Drag radials
Ok i have a quest about drag radials :skidmark
i know that the Mickey Thompson ET Street Radial 2 are a great drag tire, i 've been told the may be to aggessive for a 350 by some muscle car guys and i should look at the BFG'S OR NITTO'S, has anyone used the MT's, i want to know how they handle on a normal launch, slipping the clutch and grabbing, just lauching it hard, and how the drive train handles the grip.
Old Jul 28, 2010 | 03:33 PM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Old Jul 28, 2010 | 03:51 PM
03threefiftyz's Avatar
03threefiftyz
Fantastic DR........IMO the best on the market. I used 275/50/15's on 15" weld prostars.
Old Jul 28, 2010 | 04:07 PM
OSIRIS06's Avatar
OSIRIS06
how hard are you lauching on them, and is your drivetrain stock
Old Jul 28, 2010 | 04:10 PM
03threefiftyz
Stock trans and axles. Os Giken Clutch set-up. Anywhere from 4700rpm launches on the coldest days to close to 6000 on the hottest of days. Best 60' was in the 1.84 range from memory.
Old Jul 28, 2010 | 06:35 PM
MM'08_350Z's Avatar
Those weld wheels are 15x???? And lug parttern?
Old Jul 28, 2010 | 06:43 PM
03threefiftyz
15x8 +25..........5x114.3 (4.5"). With the soft sidewalls it wasn't a problem on the relatively narrow wheel.
Old Aug 6, 2010 | 10:11 PM
black556's Avatar
black556
Bring an extra set of axles. Learned this the hard way.
Old Aug 9, 2010 | 05:41 PM
OldManZ350's Avatar
OldManZ350
MT 275/60/15 Street Radial, Best 60 Ft 1.76, Best Et 11.85, Best Mph 118.62
Launch about 4500prm
Old Aug 17, 2010 | 06:24 PM
ffwturboZ's Avatar
ffwturboZ
Anyne experinced the wheel hop problem? Im looking to go to a DR also but wondering if there is anything else that should be done to the rear end suspension.
Old Aug 19, 2010 | 09:19 AM
izit26's Avatar
izit26
I had wheel hop and a bit of tire shake running my Hoosier QTP's @ 14psi. Nothing to be worried about though. Just get out of it if it doesn't feel right. I get some bouncing at the top end compared to running on my BFG Drags.
I run a progressive spring. I believe it helps a bit with weight transfer. The pros can interject on that.
Old Aug 19, 2010 | 09:27 AM
Nexx's Avatar
Nexx
betcha your rear differential bushing is blown.
Old Aug 19, 2010 | 01:04 PM
Lakeside's Avatar
Lakeside
I also have wheel hop depending on how I launch. I'd like to switch to DR's and smaller rear wheels. Then I should break into the 12's.
Old Aug 28, 2010 | 01:15 AM
ffwturboZ's Avatar
ffwturboZ
I checked the rear bushing and it is broken but not destroyed. In any case I will be getting the solid diff bushings and the DR. The tire hop is embarassing and not going through that episode again..
Old Aug 28, 2010 | 06:55 AM
Lakeside's Avatar
Lakeside
Link for the rear solid diff bushings? I only find ones for older Z's pre 350z
Old Aug 28, 2010 | 04:25 PM
350zhr's Avatar
350zhr
https://my350z.com/forum/drivetrain/...brace-new.html
its not solid diff bushings, but i hear it rids wheel hop well. I will invest in this one day.
Old Aug 28, 2010 | 04:41 PM
Lakeside's Avatar
Lakeside
Thanks for posting that up! I just posted over there. I'd be interested in picking one of these up. But I'll have to see whats involved in getting it to work with the finned diff cover.
Old Sep 4, 2010 | 11:33 AM
thatv35guy's Avatar
thatv35guy
Also, check out 350zmotorsports.com, they have solid bushings at a great price. I ran the SPL bushing (didn't have them in stock at 350zmotorsports at the time), but the mounts made a huge difference on my car, all wheel hop gone!
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
12SecZ
Oct 8, 2003 08:56 AM
