Drag NHRA, IDRC, IHRA, NDRA
1st Time.. Tire Pressure
Old Oct 25, 2010 | 06:18 PM
Quamen's Avatar
Quamen
Default 1st Time.. Tire Pressure
Hey guys. I am going to be taking my LS1/TH400 350z to the track for the first time this week and I was just looking to get some input on tire pressure. I have line locks so I can warm the tires up just fine. I have two options I will trying and I am just looking for suggestions on where to start pressure wise with each tire.
My first setup is going to be my current POS Falken FK-451 that I will shortly be replacing. They are 275/40/R18's. From searching it seems like I should start with around 30psi on these since they are street tires and the side walls are very stiff and short.
The second setup I am going to try, depending on my 60ft and how I hook up, is my friends 305/35/R18 Mickey Thompson ET Street Radials. It looks like I should start these somewhere around the 26-28psi range.
Any input on these starting pressures? It looks like it is going to be quite cold with temps around the low to mid 50's and the track is prepped for street tires the night I am going.
Old Oct 25, 2010 | 07:46 PM
For street tires I would start the day at 35 PSI. Drop 2 pounds after each run. See what works best. Do not recommend a burnout on street tires.
EDIT: Have fun. If the car points the wrong way in first or second gear, back off the throttle. No trophy for hitting a wall.
Old Oct 26, 2010 | 01:51 AM
Quamen's Avatar
Quamen
Why no burnout?
Old Oct 26, 2010 | 02:03 AM
0jiggy0's Avatar
0jiggy0
Because all you'll do is waste your tires.
Old Oct 26, 2010 | 05:08 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Ive run street tires to 25psi, no lower as I dont feel more traction and you're increasing rolling resistance. Id start those at 30psi and work down slow.
Et Street Radials Id start at 20psi and work down. You def wanna heat those up. Give the street tires a quick spin, that is all you need.
Old Oct 26, 2010 | 06:49 AM
scotts300's Avatar
scotts300
I think you are wasting your time on the street tires.
Old Oct 26, 2010 | 07:04 AM
03threefiftyz's Avatar
03threefiftyz
+1.
The MT drag radials....I would start at 20psi and work my way down until you find what you want in terms of traction. I wouldn't go below ~12 though.
Old Oct 26, 2010 | 08:55 AM
Quamen's Avatar
Quamen
Thanks for the input. I agree that for the most part the street tires will be a waste. I will try them once and see what happens.
Old Oct 27, 2010 | 08:11 AM
Originally Posted by Quamen
Why no burnout?
Because street tires are designed not to get hot. That is why they have a temperature rating.
Old Oct 27, 2010 | 03:50 PM
krazy4's Avatar
krazy4
Don't waste your time with street tires. lol
Run the radials.
I would start around 18 psi and work your way down if you spin. Those tires have a really small sidewall though, so higher pressure will probably hook better. (around 16-18psi)
I had some really small sidewall drag radials for awhile and they hooked better at 17psi then at 12psi or lower.
Good luck!
Old Oct 28, 2010 | 10:28 AM
Alberto's Avatar
Alberto
Cranky FI Owner
So what did you run?
Old Oct 28, 2010 | 06:38 PM
Quamen's Avatar
Quamen
Never made it to the track. Had something come loose on the way there and decided to trailer it home...
Always something, but I guess it comes with the territory when you do as large of a change as I have. Hoping to get it all fixed by Saturday.
Old Oct 28, 2010 | 08:13 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
What drag strip do you go to? If it's close to where I live, I might try to make it out.
Old Oct 30, 2010 | 04:56 AM
Quamen's Avatar
Quamen
Great Lakes Dragaway near Racine Wisconsin.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
