Drag raced at Atco drags N.J
So I finally made that trip to a drag strip(Atco n.j). I bought Hoosier slicks to see if I could cure my traction problems. At Atco you can't avoid the water. Its build with one narrow lane where ALL cars have to go thru a lake of water. This is what I learned. I don't know how to do those brake on burn outs. Slicks 26"-10"-15" are for cars 350hp & more not 300hp & less. I'm to old to change tires twice, after driving 31/2 hours
Reasults-slower 0 to 60 but decent times (spinning wet tires or bugging at line). Only my second run had a 1.850. 13.083@105.56-12.901@106.34-13.014@106.20 & a couple more 13.0 something. I learned that slicks are to much tire for me & that Z owners don't drag race. NOT ONE Z at the track. I was told they do come sometimes but are slow. A track guy told me the fastest he saw was a 14.1 SAD. p.s will get rid of slicks & go back to drag radials
I will, but I also will say the people are nice, price only 15 bucks, except for the water, its not bad at all
The 350z is a great handling street/road course car. That doesn't explain why Z drivers pull up to me to race
or why in the parking lots/get togethers all they talk about how fast/quick & powerfull their cars are
On a different subject-why can't I post in the general 350z forum if I wish to do it? I'd like to reach other Z owners & maybe motivate them to drag race at a track, not on the street. If one can't race in a straight line than they certainly can't race on a road course. I would call that taking rides/taking a spin around a road course. Sorry to be so blunt.....
rule 1: if you cant do a burn out, stick to street tires. DR's and slicks MUST have a proper burnout to function properly.
rule 2: dont complain about equipment when its not used properly.
better luck next time.
I also encountered the water box issue my first time at the drag strip. The entire lane was sprayed with water on each pass. I didn't know how to do a burnout so I tired launching the car aggressively from the water box to get the tires spinning slightly. However, I still couldn't get all the water off the tires and dealt with wet tires on every pass.
Even with not heating up the tires thru water, I still did a 12.901@ 106.34-NOT bad at all
. I'm thinking of installing a line lock. With that, I'm sure I can learn water burn outs. Oct.21 & 22nd. look good to me. Any Z racers want to come???????
??????????? No, I mean 12.901@1.06+. All the rest of my runs were 13.0something. If your thinking that its .03 better than my record, I also know it is.
I just don't want to bother changing for that little, especially with me using slicks. When I turn in the 12.8s, I'll be happy to update.
Thanks for looking out.
Andre
Oh, I just saw what you are referring to
yes its not 12.01 its 12.901 sorry
Andre
Hmm I may go out wednesday on slicks and see if I can get me some better times. The only thing with these slicks compared to my DR's is they sway ALOT more than usual. Kinda scary.
The swaying is normal and scary.. Lol with my 27" tall slicks I drop that PSI to 12 and launch it hard between 5-6.5K rpm. Take in mind I have Pro Level DSS axles (1200HP rated)
First, anyone miss me?
There was a dragster final. Dozens of them, running for money. They still gave us an opportunaty for some test/tune runs. The good news first. One of my 3 runs was a 12.874 @ 104.72. The other 2 were 12.928 @ 104.61 & 12.926 @ 105.00. My mph speed was down, possibly because of lower tire pressure. Now I'm not complaining because the times were good, & they were not at raceway park but Atco. The problem that I can't seem to solve is traction. With slicks made for much more powerfull cars than mine, I still can't leave. My 60' were 1.906, 1.901 & the 12.874 had a 1.867. This was with a newly installed line lock. Its either me or the Z suspension. There is no reason to add any bolt ons, if I can't launch my car. I think my times are getting better because it now is much cooler. In the summer, I had 1.814 & 1.824 with m/t radials, but the temperature was 100 degrees. 1.760 to 1.81 60' should put me in the 12.7's.
Any shops on L.I. that are good with drag suspension setups???
There was a dragster final. Dozens of them, running for money. They still gave us an opportunaty for some test/tune runs. The good news first. One of my 3 runs was a 12.874 @ 104.72. The other 2 were 12.928 @ 104.61 & 12.926 @ 105.00. My mph speed was down, possibly because of lower tire pressure. Now I'm not complaining because the times were good, & they were not at raceway park but Atco. The problem that I can't seem to solve is traction. With slicks made for much more powerfull cars than mine, I still can't leave. My 60' were 1.906, 1.901 & the 12.874 had a 1.867. This was with a newly installed line lock. Its either me or the Z suspension. There is no reason to add any bolt ons, if I can't launch my car. I think my times are getting better because it now is much cooler. In the summer, I had 1.814 & 1.824 with m/t radials, but the temperature was 100 degrees. 1.760 to 1.81 60' should put me in the 12.7's.Any shops on L.I. that are good with drag suspension setups???
Andre. This month I will install a ACT 6puck race clutch and pro-lite Fly. And my Test pipes I going for the 12.80s.
