Drag NHRA, IDRC, IHRA, NDRA
M/T ET Streets - Tubes and Rim Screws?
Old Mar 31, 2011 | 03:20 PM
OldManZ350's Avatar
OldManZ350
Default M/T ET Streets - Tubes and Rim Screws?
Anybody with M/T ET Streets, Running them WITHOUT or WITH Tubes and Rim Screws?
What Air Pressure are you running at?
Thanks,
TimRod
Old Apr 1, 2011 | 10:10 AM
OldManZ350's Avatar
OldManZ350
I know there are a few guys out there using ET Streets.....
Can you jump in.......
Old Apr 1, 2011 | 10:41 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I have M/T ET Streets and I run them without the tubes and without the screws.
As for the pressure, I start at around 17 psi and adjust based on my runs.
Old Apr 1, 2011 | 11:36 AM
OldManZ350's Avatar
OldManZ350
Whats the lowest air pressure you have used?
How well do they hold air?
Did you glue the Bead?
Thanks
TimRod
Old Apr 1, 2011 | 11:51 AM
03threefiftyz's Avatar
03threefiftyz
Generally speaking if you keep them above 12 w/a little extra bead seal they will hold w/o screws. If you plan to go 12 or lower....get them screwed. Tubes aren't necessary.
Old Apr 1, 2011 | 12:32 PM
ajcool2's Avatar
ajcool2
Same here. I keep mine at 16psi.
Old Apr 1, 2011 | 01:24 PM
3hree5ive0ero
Retired Admin
Thanks
TimRod
I think the lowest I've gone on these was 15.
One loses air a bit faster than the other one but over time. For a one day drag strip use, they hold air just fine and I don't have to pump them back up (unless I let out too much).
They were mounted normally at Discount Tire.
Old Apr 1, 2011 | 02:35 PM
OldManZ350's Avatar
OldManZ350
Thanks Guys,
Micky Thompson said that Tubes are Required with ET Streets, and if you install Tubes, then Rim Screws are Required........
Thanks Again, I thought I say guys runniing Without.......
TimRod
ablaine
Nov 29, 2016 10:13 AM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
