Drag NHRA, IDRC, IHRA, NDRA
Light Wheel for Drag
Old Jul 3, 2011 | 08:13 PM
djamps's Avatar
djamps
Cool, I ended up getting a 1.9 60ft on my first run... 1st gear wouldn't get them hot enough on the burnout... I was nearly redlined for like 15 seconds and they barely smoked at all before that run.
So I tried 2nd gear on my next run... tires billowing smoke within a few seconds. However, the clutch didn't seem to like it... pressure plate took a dump so my day was over. LOL I've done 2nd gear burnouts in the past without issues... either my clutch was just weak or I was too far out of the water box when I started it or both...who knows.
Old Jul 4, 2011 | 04:59 AM
f150intally's Avatar
f150intally
Which clutch were you running? What clutch will you replace it with?
Old Jul 4, 2011 | 10:47 AM
08NismoZ's Avatar
08NismoZ
Yeah thats what i've been trying my burnouts in is 2nd gear. I'm running the OS Giken triple disc clutch with that ZSpeed heavy duty CSC and a braided clutch line. I pulled my brake fuse to stop the ecu from killing the power when I put the brakes on to try and keep it still and straight, which was turning out to be pretty difficult haha
Old Jul 4, 2011 | 10:59 AM
midz350's Avatar
midz350
I can PM you the specified harness pins for the HR harness, so you can install an on/off switch to do brakeboost/burnout freely.
Old Jul 4, 2011 | 11:24 AM
2bad240's Avatar
2bad240
here is a pic of my new setup, 15x8 rear and 15x4 fronts
26x105-15 m&h cheater slicks, fronts are 165/80-15 nexens
my old setup was stock 05 wheels with 275/45-17 nitto nto5r
the stock rears with radials weighed 50.33lbs the new setup weighs 30.43lbs
Old Jul 4, 2011 | 12:02 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Never heard of those front tires. Are they properly speed rated?
Old Jul 4, 2011 | 12:07 PM
2bad240's Avatar
2bad240
they have a t speed rating, which is 118. but alot of the the local racecars around here run them. i got them at the local tire shop for $77 each installed. he said that alot of the people around here use them and dont have any problems.
Old Jul 4, 2011 | 12:23 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Are you NA?
Old Jul 4, 2011 | 12:24 PM
08NismoZ's Avatar
08NismoZ
That would be awesome, i'd really appreciate it
Old Jul 4, 2011 | 12:25 PM
03threefiftyz's Avatar
03threefiftyz
Originally Posted by Alberto
Are you NA?
Nitrous.
Old Jul 4, 2011 | 12:49 PM
0jiggy0's Avatar
0jiggy0
Nexen are korean el cheapo tires common on dubs n the like. Probly not.
Old Jul 4, 2011 | 01:03 PM
2bad240's Avatar
2bad240
i figure if a 3200lb 900hp mustang can get away with running them and trapping 122 in the 1/8th my 360hp 350z should be fine.
Old Jul 4, 2011 | 07:05 PM
djamps's Avatar
djamps
Ya u need to hit the brakes pretty hard as soon as you dump it. But I haven't had any issues staying still with slicks. With street tires it was more difficult.
Old Jul 7, 2011 | 06:46 PM
MM'08_350Z's Avatar
Bogarts FTW!!! 15x4.5 5lbs and 15x10 9lbs
Old Jul 7, 2011 | 08:35 PM
08NismoZ's Avatar
08NismoZ
Lookin' good! How are you guys fitting 15's on your car? Did you have to put on a smaller rotor?
Old Jul 8, 2011 | 04:17 AM
djamps's Avatar
djamps
Pretty sure with non-brembo you can do certain 15's. Almost looks like there could be rubbage during burnouts and high speeds... that's a tight offset and slicks have a tenancy to change shape.
Old Jul 8, 2011 | 04:23 AM
djamps's Avatar
djamps
BTW here's my setup 11.5x26x16... no skinny's for me
Attached Thumbnails Light Wheel for Drag-267182_10150230123077377_669672376_7496193_4365149_o.jpg
Old Jul 8, 2011 | 09:55 AM
  #38
MM'08_350Z's Avatar
Exactly, they are not brembos and those are my 28x11.5x15 Hoosier QTPs but it looks way better and no rubbing with my 27x10.5x15 Mickeys and my 26x11.5x15 Mickey drag radials.
Old Jul 8, 2011 | 10:27 AM
  #39
midz350's Avatar
midz350
PM'ed.
350z82
Oct 1, 2015 06:25 PM
