Drag NHRA, IDRC, IHRA, NDRA
At what RPM do I launch my Z
Old Sep 13, 2004 | 09:34 AM
Red04350Z's Avatar
Red04350Z
Default At what RPM do I launch my Z
At what RPM do I launch my Z?
Just curious
Old Sep 14, 2004 | 11:12 AM
Jaki's Avatar
Jaki
I read somewhere at 2k . Correct me if I'm wrong.
Old Sep 15, 2004 | 08:59 AM
Red04350Z's Avatar
Red04350Z
I wasn't too sure but I think thats about right.
Old Sep 15, 2004 | 12:36 PM
VeeTec's Avatar
VeeTec
Depends on your traction.
2K if its not too good, 3K if its sticky.
Anything above that on the factory tires will give you nothing but spin.
Old Sep 26, 2004 | 04:37 PM
thunder0880's Avatar
thunder0880
2500 works the best for me
Old Sep 27, 2004 | 09:41 AM
zectasy's Avatar
zectasy
i usually do it between 1500-2000k rpms..anything around 3k for me just ends up in madd tire spin
Old Oct 4, 2004 | 03:30 AM
KY350's Avatar
KY350
With your TT, its anyones guess.
Just go to the track and practice differnent rpms and try clutch dumping and slipping to see what works best for you.
Old Oct 5, 2004 | 10:45 PM
shinzter's Avatar
shinzter
slipping the clutch seems like it works best on all kinds of cars.
but at the same time, it all depends on what kind of driver you are.
Old Dec 15, 2004 | 07:09 PM
southern_info's Avatar
southern_info
2000k rpm is the best launch rpm w/o lighting the tires up???? Do you dump the clutch????
Old Dec 16, 2004 | 07:31 AM
corsair's Avatar
corsair
I have to launch at idle. Anything above that and I get bad tire spin.
Old Dec 23, 2004 | 11:38 AM
conejo's Avatar
conejo
I went dragging last weekend and it was terrible. When I launched over 2500 k the car stalled like if the traction control did not let the tires spin and about a second later it beganto accelerate himself, I has the pedal to the metal but a Mitsu 3000GT beat me.
What can I do to improve my launch tecnic. I push the traction control button but it appears it doesnot work, it doesnot lights
in the speedo and I keep on launching bad.
Please help ???
Old Jan 2, 2005 | 10:25 AM
FLZ_Boy's Avatar
FLZ_Boy
I believe traction control WILL bog down your Z to prevent wheelspin. The light will light up if your traction control is off, you might want to have the dealer check it out if you can't turn off traction control.
OR
Assuming your traction control is off during the launch, If you release the clutch out too fast, you will bog the car @~ 2000 RPMS.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Calinismo350z
Sep 14, 2015 04:04 PM
