Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
VQ35 powered 240sx
Old Mar 7, 2007 | 07:59 AM
  #61
jimmyloose's Avatar
jimmyloose
teh new hotness...
the KA motors were iron weren't they? that would explain why the VQ (aluminum) is comparable in weight... I'd still say hold off on the location for the ECU/battery/fire suppression until you corner-weight the car.
Old Mar 7, 2007 | 08:16 AM
  #62
carluch's Avatar
carluch
Originally Posted by Motormouth
how much would this project cost?
this whole project so far has cost me around 5k. BUT, i get amazing deals/parts for cheap or free all the time from sponsors and friends... once its the whole car is complete, it should tally up to about 10-15k retail to replicate... not including labor...
Old Mar 7, 2007 | 08:18 AM
  #63
carluch's Avatar
carluch
Originally Posted by jimmyloose
teh new hotness...
yeah the KA was iron block. i believe the ka actually weighs about 20 lbs more than the vq, both in full trim...
the ecu weighs about a pound, so i dont think there is much advantage to mounting it anywhere but the most convenient place...
fire suppression will be an extinguisher mounted to cage within arms reach, so its 5 pounds will be dictated by that...
and the battery is mounted in the most convenient place. im not really into modifying/changing stuff just for the sake of making it seem better. i usually need it to actually be better. with the 4-500 or so pounds ive taken from the car, i doubt that wherever i mount the battery will make anything but a marginal difference in the balance/handling of the car...
Old Mar 7, 2007 | 08:28 AM
  #64
jimmyloose's Avatar
jimmyloose
every little bit counts I was thinking about that after I posted... There's not really anything else that weighs much that needs to be mounted.
Old Mar 7, 2007 | 09:03 AM
  #65
Motormouth's Avatar
Motormouth
did you stitch weld the chassis? or do any reinforcing?
and how many hours of labor would you guestimate the swap cost? (just the engine swap and getting it running, not body mods and such)
Old Mar 7, 2007 | 09:13 AM
  #66
carluch's Avatar
carluch
yup, the chassis is stitch welded in all the sweet spots... there will be a scca/formulad spec cage installed before completion...
as far as just getting the motor in, its hard to say. i basically have been building the car from the ground up...
if it were just a vq going into a stock 240 (stock chassis wiring, no chassis prep at all) i would say it would take anywhere from a weekend to a week of actual labor. but, thats in the case that you have every part on hand to begin with. nothing toooo hard about it, just a lot of details... motor/trans mounts, driveshaft, rear differetial, shifter, fuel system, exhaust, wiring, etc...
Old Mar 7, 2007 | 08:48 PM
  #67
FastZ33's Avatar
FastZ33
hows the car going bro?
Old Mar 7, 2007 | 08:53 PM
  #68
stepuckey's Avatar
stepuckey
yeah, update! (pics)
Old Mar 10, 2007 | 11:02 PM
  #69
FastZ33's Avatar
FastZ33
picsssss
Old Mar 10, 2007 | 11:23 PM
  #70
DXJP's Avatar
DXJP
DUH why the 4 hazard switches
just f in with ya
lorin
Old Mar 11, 2007 | 06:11 AM
  #71
carluch's Avatar
carluch
just f in with ya
lorin
arent you in tochigi? ask koguchi hahahaah
Old Mar 11, 2007 | 09:10 AM
  #72
DXJP's Avatar
DXJP
I would but Im back in the sand
Old Mar 11, 2007 | 10:36 AM
  #73
The Z Guy's Avatar
The Z Guy
Look Good............Good luck with the car and the upcoming drifting events. I'll try to get a chance to see this car whenever you guys stop by the next drifting event.
Old Mar 21, 2007 | 05:28 PM
  #74
Zmazing03's Avatar
Zmazing03
Very cool project. Any picture updates??
Old Mar 22, 2007 | 07:12 AM
  #75
carluch's Avatar
carluch
no new pictures yet... been consumed with gathering engine management parts... may not be going with oem management after all...
Old Mar 22, 2007 | 10:22 PM
  #76
03Z33's Avatar
03Z33
Keep us updated on what you end up running, if you're straying from stock ECU it MUST be something special!
Old Mar 26, 2007 | 03:25 PM
  #77
crmd37's Avatar
crmd37
hey man, keep us updated as i am ALSO doing this project. i have been waiting for my brian crower stroked motor for a LONG time and it'll replace the stock vq35 so i will be placing that into my 1995 240sx s14. got the vq tranny, ecu, bcm, throttle body, pedal assembly, ignition stuff and a few extra things that'll help out the swap. either way, i'd like to know of anything that might be difficult so i can plan ahead and knock it out. where abouts do you live? how far away are you from getting this done? lemme know man as i am willing to share info on mine as well but later down the road since i'm still waiting to yank my stock motor outta my g35 so i can throw it in the 240. also i'm pretty sure the VQ weighs significantly less than the KA, i mean you're talking about aluminum vs. cast iron...HUGE difference. send me a pm if anything as i am not on here much!
Old Mar 26, 2007 | 03:26 PM
  #78
DJShan209's Avatar
DJShan209
One word: Sick
Old Mar 26, 2007 | 03:31 PM
  #79
TuscaniJon's Avatar
TuscaniJon
that car is going to be so fun to drive!!!
Old Mar 26, 2007 | 04:16 PM
  #80
scratch137's Avatar
scratch137
Not that it may matter to you, but in the new issue of Import Tuner, they have a convertable black 240sx w/ a VQ35DE swapped. It going for the VIP style and is pretty damn hotttttt. Check it out, it may help you some idk.
