Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Sam Yousif's 350z Pro-Am Drift car V8 build
Old Dec 27, 2010 | 10:13 AM
Zorgazm's Avatar
Zorgazm
Default Sam Yousif's 350z Pro-Am Drift car V8 build
Hey all,
I have been debating for a long time whether I want to go with a chevy LS swap or a VK56 and have made up my mind on the LS1.. yes good choice.
The process has already started, I have accquired a complete LS1 swap and a T56 6 speed trans. We have stripped the car down to a bare minimum as we are getting ready to mount the LS1 swap. There will be no cross member or firewall modifications at all so this should be a non difficult swap.
I will be doing some bolt ons to the LS1 such as custom long tube headers, cams, and springs before the initial fire up. Will keep you guys updating, let me know what you think
<a href="http://s11.photobucket.com/user/xinsanechaldox/media/216570_1662948533668_1235871934_1319592_2540553_n.jpg.html" target="_blank"><img src="http://i11.photobucket.com/albums/a191/xinsanechaldox/216570_1662948533668_1235871934_1319592_2540553_n.jpg" border="0" alt=" photo 216570_1662948533668_1235871934_1319592_2540553_n.jpg"/></a>
Old Dec 27, 2010 | 10:14 AM
Zorgazm's Avatar
Zorgazm
Heres the LS1 motor swap, Arrived a while ago, it has been taken a part for a little bit of internal work to be done.
Look at this dash harness I took out along with stock computers..all together weighed about 75 pounds not including engine harness
Old Dec 27, 2010 | 10:44 AM
ImWeeZzel's Avatar
ImWeeZzel
suscribed
Old Dec 27, 2010 | 11:11 AM
CRIDDA's Avatar
CRIDDA
In for the win
Old Dec 27, 2010 | 11:39 AM
TAHorizon's Avatar
TAHorizon
Good luck with the buld, and I can't wait to see your build's progress. Do you have a projected completion date for this project?
Old Dec 27, 2010 | 11:52 AM
SamSpicer's Avatar
SamSpicer
looks sick
Old Dec 27, 2010 | 12:03 PM
Zorgazm's Avatar
Zorgazm
Thanks a lot guys, the swap is in its final stages. We are using Fueled Racing's LS1 mounting kit along with their headers. The kit is very high quality and priced right so I couldn't say no to that.
Old Dec 27, 2010 | 12:33 PM
ITOzann's Avatar
ITOzann
one more LS powered! sub'ed!
Old Dec 27, 2010 | 03:25 PM
ImWeeZzel's Avatar
ImWeeZzel
lolz @ the Op\s user id
Old Dec 27, 2010 | 07:22 PM
AngelsVQ's Avatar
AngelsVQ
good choice
Old Dec 28, 2010 | 12:15 AM
AmorZ_Fati's Avatar
AmorZ_Fati
*sigh*
The fact that everyone is switching to V8 is ruining the "sport." All is well I guess because IMO grassroots is where drifting belongs, but still...The VQ has more than enough power to achieve desired angle/speed...just my .02
Old Dec 28, 2010 | 09:23 AM
AngelsVQ's Avatar
AngelsVQ
Originally Posted by AmorZ_Fati
*sigh*
Why would that ruin the sport... There are pros and cons to everything you decide to put on your car.
Old Dec 28, 2010 | 10:15 AM
BEBO'S ZEE's Avatar
BEBO'S ZEE
In for updates
Old Dec 28, 2010 | 10:19 AM
Zorgazm's Avatar
Zorgazm
Thanks a lot guys. I went with the V8 because of the fact that is very reliable under extreme conditions and parts are available everywhere for the LS1. Not to mention the added HP and TQ needed to be competitive against other drivers out there with high HP cars.
Sure if everyone had a VQ then I wouldn't have a problem staying with a VQ, but the fact that everyone is going with very high HP setups, I must do the same in order to stay competitive in the series.
The Texas Speed Magic Stick cam kit is being installed, which includes Cam, springs, retainers, lifters, and push rods - (stage 4) 60-80whp and up to 100whp of RAW V8 Powaaaa
Ported oil pump
ARP rod bolts
GMPP LS2 heavy duty timing chain
Thats going to be all the internal motor work im going to do for now.. after a good tune I should be at about 450whp and about 440 ft tq
MUCH thanks to Fueled Performance Racing.
I wanted to show you guys the switch panel I ended up going with. its the ARC 8000 with 50 amp relays, I like this one a lot better than the old school toggle switches. Its a flat touch panel which can be mounted to a roll cage as well as a dash.
Old Dec 29, 2010 | 11:13 AM
Twenty4's Avatar
Twenty4
not sure why you would need a v8 for Pro-Am, but your switch plate is baller as $hit!
Old Dec 29, 2010 | 11:33 AM
terrasmak's Avatar
Dam, and hell ya. Can't wait to check it out next time your in Vegas.
Old Dec 29, 2010 | 03:25 PM
Count Driftula's Avatar
Count Driftula
awesome build! keep the updates coming!
Old Dec 30, 2010 | 09:38 AM
Zorgazm's Avatar
Zorgazm
Thanks a lot guys, more parts coming in soon.
Old Jan 12, 2011 | 10:25 AM
Zorgazm's Avatar
Zorgazm
Almost done and I am hoping to have it complete before the first drift event here in AZ on the 21st. Will update with pictures soon
Old Jan 13, 2011 | 06:02 AM
BoomerZ33's Avatar
BoomerZ33
good luck with the rest of the build. in for finished pics.
