Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
How well does the 350Z drift
Old Feb 12, 2004 | 12:45 PM
350ZOWNZ's Avatar
350ZOWNZ
Default How well does the 350Z drift
Just curious how well does it drift? What kind of cars compare to it in drifting? Is it like the S2000? worse? 300ZX?
Thanks
Old Feb 12, 2004 | 12:54 PM
aalzuhair's Avatar
aalzuhair
Very well, check out the link
https://my350z.com/forum/showthread....threadid=60610
Old Feb 13, 2004 | 11:15 PM
DRFT_Z33's Avatar
DRFT_Z33
heres a link im looking for more haha watch the one with the demo runs the rsr 350 is there and a supra
link - http://www.willraceforfood.com/videos/rsr_drift.htm
Old Feb 20, 2004 | 05:28 PM
350ZOWNZ's Avatar
350ZOWNZ
would it compare to a S2000 in terms of drifting ability tho?
Old Feb 20, 2004 | 07:19 PM
mofoz's Avatar
mofoz
light front engine rear wheel drive cars are the best for drifting usually. any car can pretty much drift, just different techniques and such. One of the main things you need is enough power to spin the tires and kick the rear out and a proper suspension setup. I think both S2000 and 350Z could drift farely well.
Old Feb 20, 2004 | 07:23 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
probably different than s2000, since 350z is heavier...
from the video of 350z and supra, the 350z seems easier to break out the backend than supra? it reacts quicker than the supra.. maybe it has something to do with the driver as well.
Old Feb 21, 2004 | 08:04 PM
Topics II's Avatar
Topics II
the s2000 is not too good of a drift car without proper work. ive drifted a stock z and a stock s2000 and the z was totally better. ive drifted modified z's (obviously ) but not modified s2000s, im waiting for someone to set one up for serious drift and see how it does. it has at least a good amount of potential to be built into a good car.
Old Feb 25, 2004 | 06:19 PM
tougeracing's Avatar
tougeracing
i thought the s2000 engine was built already to its potential? i heard its hard to boost the power anymore w/o custom fittings :\ well i could be wrong, u should listen to Topic II hahaha
Old Mar 21, 2004 | 07:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Stock the Z drifts ok, after installing better tires and some JIC coilovers, drifting is so much better, the car stays more controled even when its sliding--if that makes sense. All you have to do is let off the gas and the rear comes back in check nicely. I love JIC's...
Old Mar 22, 2004 | 12:39 AM
Topics II's Avatar
Topics II
Originally posted by Alberto
the car stays more controled even when its sliding--if that makes sense...
of course it does! it controls the weight transfer so the spongy stock suspension doesnt throw you around when in drift.
Old Mar 22, 2004 | 03:51 AM
John's Avatar
John
Doesn't a longer wheelbase help in controlling drifts? If that's the case, then the Z should be easier to drift than the S2000. Mind you, I'm using the term "controlled drift."
Old Mar 22, 2004 | 11:22 AM
Topics II's Avatar
Topics II
See, another good thing about the z is that it is a pretty small car. but! it has a very long wheelbase. the wheels are placed outward towards the corner of the car giving it a long wheelbase, and a wide track, without having a 20ft long car. there is very little overhang with the bumpers and makes it much easier to "know" where your front and rear end is, and lets you fit through tighter spaces.
Old May 16, 2004 | 08:28 PM
Tekkanano's Avatar
Tekkanano
Topics II, what do you think about the STI drifting? You can change the ratio between front and rear power, 35% front, 65% rear. Do you think the STI has a better chance at drifting easily in stock form vs. a stock 350Z?
My opinion is that with the power ratio change and the turbo, it will make the STI easy to drift without modding too much.
I've been in an EVO8 and he could only slighty drift it.
Old May 18, 2004 | 10:35 AM
Topics II's Avatar
Topics II
AWD drifting is totally different then RWD drifting. You have to use alot of weight transfer, and you loose ALOT of speed when putting it into a slide. you may be able to get it sideways through a turn, but its not as easy, or nearly as competitive as a RWD.
Old May 27, 2004 | 12:12 PM
phoenixZ33's Avatar
phoenixZ33
A G35 Coupe is a very good drift car as well, you can really feel the difference with the longer wheelbase. I thought the G35 was easier to control with big angles and I found myself spinning, or coming close to spinning, less. The stiff chassis combined with the linear throttle and steering in both cars makes them excellent for drifting.
Old Jun 26, 2004 | 02:20 PM
Akira's Avatar
Akira
S2000 is not a good drift car. It's too well balaced. 50/50 ratio car is really hard to drift. The input is so sensitive and if you make little mistake, the tail will come around faster then you can say Ooops. Z in the other hand is more forgiving. So it's easier to drift.
Old Jul 26, 2004 | 11:42 AM
RazNips's Avatar
RazNips
ive had trouble in wet slick roads with my G coupe because once the back end starts sliding out, its really hard to pull back when its wet out. When its dry i can get extreamly sideways and control it but when my car lines back up its not smooth because of snap oversteer thats really bad. I am a little intimidated by my G now after spinning the back end around a few times and now i am a little timid when in a public road so i have not mastered the controled countersteer yet with this car.... its no 240 thats for damn certain
Old Aug 4, 2004 | 08:27 AM
Cougs's Avatar
Cougs
Both the Z and S2000 can be drifted...the Z, because of the weight the sits in the front of the car (53F/47R) the front stays slightly more planted allowing for snap oversteer when the larger amount of available torque breaks the tires loose. The S2000 is more tailhappy, when means the drifts can be more prone to excessive oversteer and can cause the back end to overreach its limits. Having a slightly thinner tire in the rear on either of these cars matched with slightly stiffer rear springs will change drift characteristics considerably, making both quicker to step out.
Also, having a Base model Z or a Z that has had the VDC shut off will make drifting easier. A clutch type LSD set at a low setting will also assist as the tires will be quicker to spin when they are not working in consort. With the S2000, because of its lack of bottom end power, will be harder to break traction: using inertia and weight transfer to loosen the tires, one can then spin them more easily because the tread will not be on its normal directional/gripping "plane".
Old Aug 13, 2004 | 05:07 PM
Scott Webb's Avatar
Scott Webb
I would think that the narrow and peaky powerband of the S2000 would be a disadvantage for drifting as well. The torque of the Z and the more linear power delivery make modulating rear tire slip easier.
The S2000 is also known for snap oversteer at high speed, which would be tough to control or anticipate.
Old Sep 4, 2004 | 07:00 PM
ReavTek's Avatar
ReavTek
After seeing drift king, Tsuchiya-san, destroy all opponents in a modified S2k I am convinced the S2k is a superior drift car. It's just harder to control at first but you will soon master it.
The 350z is just plain heavy, but you can make up for it with throttle input and liberal use of the steering wheel Also, VDC really messes up drifting fun. So, either buy a 350z that does not have VDC or get the VDC disabled. On the 350z Shock Best Motoring video they said even when you toggled the VDC off the car would control your breaks and the LSD to to prevent drifting... So yeah that's why I bought an enthusiast!
Anyways, to end my post I would just like to repeat that my choice for the better drift car would be the s2k but then again I am an oversteer happy nut. Also, look into MRs. No matter what anyone says I have to state that Mid-Engine cars are the real-mcoys of drifting. Check into the MR2 line, including the new Toyota MR2 Spyder. Small, inexpensive, MR Layout. The Drift King spun an MR2 in his "Drift Bible" video... So, if drift king still has troubles controlling an MR you know it's gotta be freaking awesome.
