FS: RPS Max Single Disk + Flywheel. Best Single Disk for Z
Hey guys,
I am trying to sell my RPS clutch and flywheel. It held 640rwhp and 599ftlbs on a DD dyno without any signs of slipping. Looking to get more power so I decided to upgrade to a triple disk.
Clutch has about 800 miles on it. This is the best single disk clutch you can get for the 350z.
The specs on the clutch are:
MAX pressure plates offer 400 to 600 pounds of extra clamping force to hold your biggest power. Pedal feel is stiff to very stiff and engages quick and smooth. RPS is the only clutch company with a U.S. Patent (#5,769,973) on their single diaphragm pressure plate technology. Our unique dual diaphragm technollogy allows us to create almost any clutch unit with any pressure ranging from stock to double stock in 100 pound increments. Torque Cap: 625 Pressure Increase: +67%
The specs on the flywheel are:
This flywheel for the 2003-2006 Nissan 350z is designed to be used with RPS'S race proven Nissan 300ZX Sport and MAX Series clutches. This is the last flywheel you will ever have to buy. The patented segmented heat shield design will not warp like other common one piece heat shields. All our CYN-R-G flywheels are highly engineered with these benefits like dynamically balanced, crushed Heli coil inserts, stepped dowel pins, and over-sized lock-down bolts that are welded to the ring gear for positive retention. This also features a precession steel ring for the drive-by-wire pick up signa
Now on to the pics:
I am asking 750 shipped for both. PM me with any questions.
Now on to the pics:
So sorry if im mistaken (drive train stuff is new to me) but isnt this the same kit NEW for 50.00 more ? or is it better since the stuff has been broken in ?!?
http://intensepower.com/rpsspseclcyf.html
350Z_Al
Oct 29, 2020 07:44 PM
