got mines installed and fitment was pretty good. sounds pretty good w. my borla exhuast and its not that lound also just a bit of rasp but i ain't complaining for the price.
^It's probably better to run HFC's if you have lots of other breathing mods. I had pretty much all the breathing mods and test pipes were the last one to be installed, after that the car kept stuttering and stalling. Definitely needed a reflash, but I took them off instead and put OEM cats on and problems were gone.
hmm..was it the pipes that caused the stalling or the sensors?doing my emissions tomorrow and reflash next friday. was thinking of installing these with the reflash...
basically, his air-fuel ratio was too lean. The reflash will take care of the AFR.
What they said, my ECU was pretty much maxed out for breathing. I had all the breathing mods possible except headers and cams.
A retune would have fixed my problem easily as well as gain tons more power. I already had non-foulers on the test pipes, so that was no problem for any sensors.
