LF: Built N/A motor
Old May 27, 2009 | 09:56 AM
jacky ngai's Avatar
jacky ngai
Default LF: Built N/A motor
Hello,
I'm looking for Built N/A motor used or new. Let me know what you have or you know someone that professional built motor.
Thanks
Old May 27, 2009 | 10:03 AM
Reality350's Avatar
Reality350
Why not just build one?
PM Ed@aph
or call
http://www.advancepowerhouse.com/contactus.html
They can get your motor built for you.
Old May 27, 2009 | 04:10 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
make a reasonable offer for the motor in my car, or the full car
Old May 27, 2009 | 07:02 PM
jacky ngai's Avatar
jacky ngai
Where is the info of your motor?
Thanks
Old May 27, 2009 | 07:18 PM
Kwame's Avatar
Kwame
https://my350z.com/forum/na-builds/2...p-to-nuts.html
Old May 27, 2009 | 07:47 PM
jacky ngai's Avatar
jacky ngai
Internals:
Weisco Pistons (.020 over stock)
Eagle rods
ARP rod bolts
Fully balanced and blueprinted - not only balanced as individual components, but also balanced as a rotating assembly
OE Nissan bearings
Full Ported and polished heads
5 angle valve job (stock Nissan valves)
Tomei 268 cams (268 duration, 10.5mm lift)
NISMO valvesprings
NISMO headgaskets
Lots of time spent porting stock, non rev up lower plenum -we logged over 100 hours between the heads and plenum, going off recommendations from MCR Japan, as well as things we found on our own.
Motordyne 1/4 inch spacer
ATI crank pulley
New: water pump, rev up oil pump, idler pullies (OEM)
All included? And how many km on the motor right now?
Pm me your price ship to Canada.
Thanks
Old May 28, 2009 | 04:21 AM
Z1 Performance
Former Sponsor
the motor has 10k miles on it, can include a new Haltech with wideband (new), Racepack dash, as well as JDM cluster (9k rpm tach), 370cc injectors, Cosworth plenum, ARC oil pan. Optionally can include OS Giken Super Single clutch/flywheel (aluminum cover version)
as I said, make an offer - no point in me setting a price if you're not in the ballpark
