Shift light modification
Old Jun 8, 2009 | 06:02 PM
anth72's Avatar
anth72
Default Shift light modification
Has anyone tried this in the Toronto area?
https://my350z.com/forum/exterior-an...ift-light.html
I've been researching it but I don't feel comfortable soldering onto a circuit board. I wouldn't mind paying for this mod if any of the local vendors/shops have done this before. Stock shift light sucks when your screaming around a race track and I don't want a huge aftermarket light that looks nasty on a street car.
Old Jun 9, 2009 | 10:47 AM
Kiriller's Avatar
Kiriller
Its not hard to do this mod at all, all u need to do is is disconnect the stock red light, and split the output for two led's and mount then anywhere you want.
For me i like the stock light =), look around kijiji/craigslist, there was a shop that was offering audi style headlight mod, im sure they will do this for you. good luck
Old Jun 9, 2009 | 10:56 AM
anth72's Avatar
anth72
Cool thanks. I haven't taken apart the instrument panel yet to see what it's like. But it sounded as if I was soldering onto a circuit bored. I'll have to investigate it further when I take it all apart.
Old Jun 9, 2009 | 11:36 AM
stanleylee's Avatar
stanleylee
how about making sound while the shift light turn on ?
anyone know how to do it ?
Old Jun 9, 2009 | 05:31 PM
XuperXero's Avatar
XuperXero
^Use the LED light power source and hook up to a mini speaker/buzzer.
Old Jun 9, 2009 | 05:32 PM
XuperXero's Avatar
XuperXero
Keep in mind, it's taking the dash apart that's a PITA
Old Jun 9, 2009 | 06:53 PM
Kiriller's Avatar
Kiriller
regarding buzzing sound or beeper, im sure you can find anything like that at electrosonic in markham. Buzzing/beeping sound is a good idea, but can get annoying quick. There could be a switch installed though to simply cut the power to the beeper for the time being, but why not just listen to the engine or feel the car?
My method that i have just tolled you, will give lower current to the 2 bulbs that re going to be powered, therefore they will be a bit darker, unless you go for the smallest bulb with the lowest voltage drop.
ps there will be a little soldering required, only to tap into the source where the stock light is powered, rest is all wires.
Old Jun 9, 2009 | 07:12 PM
XuperXero's Avatar
XuperXero
I rather install a nice 6" 10,000 rpm Monster Tach with blue green red shiftlights in gold face
Uriyo_
Sep 8, 2021 08:46 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
