Will these N/A mods make me run lean???
Old Nov 24, 2004 | 01:57 PM
TreFifty's Avatar
TreFifty
Default Will these N/A mods make me run lean???
Can anyone tell me if I should be concerned about running lean with the following mods without the TS ECU re-flash? My Z is an '05 model so I'm not sure if TS has a re-flash available yet.
I was told that I shouldn't be concerned with the listed N/A mods. FYI, I don't plan on running a dyno to monitor A/F. Just wanted some basic input from people with knowledge, or who've dynoed with similar mods.
-Fujitsubo Legalis-R exhaust
-Fujitsubo y-pipe
-DC SS headers
-Kinetix resonated test pipes
-Injen CAI
Old Nov 24, 2004 | 02:03 PM
westpak's Avatar
westpak
SFZCC
Probably, it all depends where you start from, all Z's seem to be a little different, have you dynoed yet to see what your AF is right now?
I was running around 12 before and ended up at 13 with similar mods minus the headers. But I have seen some at 14 already without many mods, I would suggest a base dyno.
Old Nov 24, 2004 | 02:07 PM
axxizzer's Avatar
axxizzer
if i were you, I'd just shell out the 600bucks for the TS reflash, peace of mind is the shiznite!
Old Nov 24, 2004 | 02:10 PM
TreFifty's Avatar
TreFifty
I would like to get the TS re-flash, but I don't think it's available for the '05 models
Old Nov 24, 2004 | 02:20 PM
TreFifty's Avatar
TreFifty
No I haven't had the chance to dyno yet to monitor A/F. My Z is very young at 1,100 miles and I'm modding at such a quick rate that the concern of running lean caught up with me. Without a re-flash, do you think that the listed mods would be safe? I don't want a blown engine.
Old Nov 24, 2004 | 03:02 PM
axxizzer's Avatar
axxizzer
ah didnt see that part
then Id try not to bring it near redline and wait till TS has a reflash available
Old Nov 24, 2004 | 03:15 PM
TreFifty's Avatar
TreFifty
yea, sucks.... Wish they had the re-flash available for '05's. Damn emissions!
Old Nov 24, 2004 | 03:22 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Lots of people run those mods without any ecu upgrade. I think your safe (unless you already have a modified ecu?).
Old Nov 24, 2004 | 07:28 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the short answer is there is absolutely no way to know how your car will react until you install the mods, hook a wideband and a datalogger up and do some runs on the street. Some cars will run lean, some will run very rich...cars are like fingerprints guys and no 2 tend to be identical.
adam
Old Nov 24, 2004 | 07:38 PM
lovetoclown's Avatar
lovetoclown
I have the same set-up. YOU WILL BE FINE.
Old Nov 25, 2004 | 07:13 AM
zzzya's Avatar
zzzya
The only way you will know for sure is to get some A/F readings. I agree with Adam, get a wideband installed so you can log the numbers. This will give you some assurance now and down the road with other mods. A dyno will help you know at this time with those mods. I don't think there has been enough info and experience with the 05 model ECU out there yet to know how it will react to mods. Even then, these engines and ECUs all respond a bit different to mods and we are all in differing climates and elevations. So many factors to take into accout.
Old Nov 25, 2004 | 07:34 AM
ZBoater's Avatar
ZBoater
You should dyno to see where you are at. I have similar mods and seem to be running fine without the ECU flash. Here's my AF readings:
I may do an ECU reflash when one is available to see if I get even better performance, but the 04 ECU flash isnt out yet, so dont expect the 05 flash any time soon.
Old Nov 25, 2004 | 08:44 AM
TreFifty's Avatar
TreFifty
Thanks for all the input. I'll head out for a dyno run and see what my A/F is reading.
Too bad that the '05, let alone the '04 TS re-flash isn't available yet. Technosquare is like a 10 minute drive away from where I live.
Say I get a A/F and it turns out I'm running lean. Without the ECU re-flash, do I have any other options?
Old Nov 25, 2004 | 03:50 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I dont know of anyone or heard of anyone with those mods that have had a problem. Only problems I know of have been with FI cars.
Old Nov 26, 2004 | 12:37 PM
zlex's Avatar
zlex
Its not possible for you to have a blown engine from the aforementioned mods.
Old Nov 27, 2004 | 12:16 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
If you are running lean, then see what progress Altered Atmosphere is making.
Dymsi
Sep 29, 2015 11:32 AM
35reilly
Sep 28, 2015 07:42 AM
codek
Sep 28, 2015 03:03 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
