Redline 75W90 gear oil is the THICKEST STUFF EVER!
Old Nov 28, 2004 | 12:17 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Default Redline 75W90 gear oil is the THICKEST STUFF EVER!
So my car is jacked up outside and I'm sitting in here waiting for the gear oil to drain out of the funnel and into the differential. I started the first quart about a hour ago...and it's MAYBE 3/4 in. Anyone else had this experience with the redline gear oil taking FOREVER to go into the diff??
oh..I'm using a funnel and tube system and filling from the right rear wheel well as I couldn't figure out a better way to do this.
Old Nov 28, 2004 | 02:44 PM
Michael-Dallas's Avatar
Michael-Dallas
1- Buy a Sta-Lube hand pump from Harbor Freight for $8.00;
2- Buy a 1 gallon bottle of windshield washer fluid for < $2.00;
3- Remove washer fluid, wash inside of bottle thoroughly, let dry, and fill it w/ diff oil;
4- Install Sta-Lube hand pump on washer fluid bottle;
5- Start pumping.
Also, in this weather, you may want to safely microwave (or heat up) the diff oil for a few seconds to warm it up (it'll flow easier warm than cold).
Also, Redline has an even thicker diff oil. It's pink and flows like Pepto even in warm weather. A buddy of mine put that in his Porsche 993.
Michael.
Old Nov 28, 2004 | 03:20 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
5- Start pumping.
Michael.
Thanks for the tip..wish I'd found out about this sooner
The diff is finally filled and I almost froze my a$$ off waiting for it. I'll have to order this for next time.
Old Nov 29, 2004 | 08:01 AM
Jung918's Avatar
Jung918
how does she drive now?
Old Nov 29, 2004 | 03:00 PM
LaidbackRacr's Avatar
LaidbackRacr
5- Start pumping.
Thanks for the heads up I will try that out this weekend. I was curious how much a pain that would have been.
Old Nov 29, 2004 | 04:33 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
feels no different than before...just have the peice of mind that I have a really good synthetic gear lube in there that will hold up to my abuse.
Old Nov 29, 2004 | 09:43 PM
dchi_t's Avatar
dchi_t
curious, i was recommended to use MT-90 in my diff...have i mistakened?!?!? i was going to buy the 75/90 gear oil instead, but so many ppl said to use MT-90....im worried
Old Nov 29, 2004 | 10:03 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Do not use MT-90 in the diff...you need a gear oil with limited slip additive. I would highly recommend the Redline Heavy shockproof gear oil that I used...
Old Nov 30, 2004 | 07:56 AM
dchi_t's Avatar
dchi_t
i have a base so i do not have a lsd, should i still swap out the oil? how serious is having MT-90 instead of 75w/90 hear oil in the diff? because getting the oil in there is such a pain in the ***.
Old Nov 30, 2004 | 09:44 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Didn't even notice that you have a base model.
I couldn't make that call. I'd contact redline and see what they think. They are very helpful with questions such as yours.
Old Dec 1, 2004 | 12:52 PM
jrotaryb's Avatar
jrotaryb
MT-90 is supposed to be thick and it's the reason why it helps with smooth syncro action...the syncros actually need a bit of friction to work and gar oil that is too slippery impedes this. The other benefit of the MT-90 (and most synthetics) is that they perform much better in colder weather and prevent excessive notchiness.
Old Dec 1, 2004 | 12:57 PM
dchi_t's Avatar
dchi_t
so jrotaryb, mt-90 is ok in the diff??
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
sherm
Apr 11, 2020 05:21 PM
kyin
Oct 15, 2015 05:54 AM
