350EVO 3.9 vs. OEM 3.5 chart
Old Dec 8, 2004 | 07:12 AM
dwnshift's Avatar
dwnshift
Default 350EVO 3.9 vs. OEM 3.5 chart
Thought this would help.
Cheers
BJ@350EVO.com
Old Dec 8, 2004 | 08:07 AM
Skrill's Avatar
Skrill
Hmm ... is it possible to get it in a larger size?
Old Dec 8, 2004 | 08:18 AM
dwnshift's Avatar
dwnshift
We worked on this gearing for awhile and it the closest thing to a 4.0 we could get. We can do custom ring and pinions but it will take 4 - 6 weeks and be in the $2500 range for a one off set. There are some critical measurements that need to be calculated when doing a ring and pinion.
Cheers
BJ
Old Dec 8, 2004 | 08:21 AM
MY350Z.COM's Avatar
BJ can you post a bigger picture.
That one is too small on 1600 x 1200. I need to get my magnifying glass out.
Old Dec 8, 2004 | 08:32 AM
JeffR116's Avatar
JeffR116
Cheers
BJ
I think he meant the picture
Old Dec 8, 2004 | 09:06 AM
Skrill's Avatar
Skrill
Exactlyt BJ ... I can't really see the graph.
BTW, my sways came, thanks.
Old Dec 8, 2004 | 09:44 AM
Srivero297's Avatar
Srivero297
two things:
1) ditto on the bigger picture
and 2) sorry for not knowing much about transmissions, but can someone interpret the graph a little?
I've read some really good stuff about the 3.9 final drive so far. From the little I know about transmissions, increasing the final drive increases acceleration at the cost of top speed, while decreasing the final drive will give you a higher top speed at the cost of acceleration? Is this correct?
And then, I guess the graph is illustrating this?
Old Dec 8, 2004 | 09:55 AM
John's Avatar
John
Correct.
Old Dec 8, 2004 | 10:22 AM
Redfoot's Avatar
Redfoot
A little blurry but you get the picture.
This is by far the best performance mod I have installed on my Z!!!
Old Dec 8, 2004 | 10:33 AM
jeffw's Avatar
jeffw
Y'all need to install Mozilla FireFox and the Image Zoom plugin.
While we're at it, the moderator(s) should
change the way image attachments are downloaded.
Jeff
Old Dec 8, 2004 | 11:14 AM
jpc350z's Avatar
jpc350z
Guess I am the only one that doesn't see it as you all do.. If you look at the 4k rpm in 4th it says that the 3.9 is going at 60mph and the OEM would be at 70mph..Nothing about acceleration in the data is inferred..What am I missing here..? Are the colors reversed?
Old Dec 8, 2004 | 12:29 PM
dwnshift's Avatar
dwnshift
Its actually 61 MPH with the 3.9 and 68 mph with the 3.5 at 4000 RPM in 4th gear. I wish I could post a little bigger with better quality
Old Dec 8, 2004 | 01:06 PM
etx's Avatar
etx
Great, I can install this FD and I'll be shifting right at the trap! j/k Good work!
Old Dec 8, 2004 | 01:27 PM
zillinois's Avatar
zillinois
Here's a interpretation of the info. ;-)
This is my car before and after the 3.9. (Plus the Tilton flywheel)
But you can see that the hp curve is shifted over to the left so
that at any give speed when you tromp the pedal, you will
have more power to draw on because rpms are higher. I lost
about 15mph in 5th gear. Thank Nissan for 6 speeds!
Old Dec 8, 2004 | 01:49 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Seems this kit will benefit road course racing (REAL racing jk) more than it would the drag racer.
Old Dec 8, 2004 | 05:31 PM
Srivero297's Avatar
Srivero297
20rwhp? Those are impressive numbers.
Im starting to think maybe that $2250 is worth it.
Im just so broke right now that I can think whatever I want and it wouldnt really change anything
Old Dec 8, 2004 | 06:44 PM
orhanz33's Avatar
orhanz33
i though it was only $850
Old Dec 8, 2004 | 06:50 PM
Srivero297's Avatar
Srivero297
I checked the 350Evo website, and it said 2250 w/ a Nismo limited slip differential included.
Damn, if its only 850 I'd definately get it.
Old Dec 8, 2004 | 07:17 PM
the bluez33's Avatar
the bluez33
wow... with mustangs this is a ~$200 mod. i take it this isn't simply another gearset?
http://www.partshopper.com/fordmusta...4209-G410.html
Old Dec 8, 2004 | 07:31 PM
350G's Avatar
350G
Economics at its best . . . supply & demand
There's so many Mustangs and aftermarket manufacturers that parts are relatively inexpensive when compared to ours.
I'm on the fence line since its a great product, but at a premium price. BUT, they did do the hard work to develop it, so it should pay dividends (its such a toss-up).
G
