how easy is it to change spark plugs?
Old Dec 10, 2004 | 08:28 AM
sentry65's Avatar
sentry65
the burninator
Default how easy is it to change spark plugs?
Are there any tutorials or threads that give any details on changing them or is it really pretty easy?
I'm new to engine modding, but it seems like you just unplug the sensor, unbolt the plug bracket, then I'm guessing you just drop them in and bolt them back in right?
Or is it more involved than that?
Old Dec 10, 2004 | 08:53 AM
mdacko's Avatar
mdacko
its really, easy, you have to take your strut bar, engine cover, and intake off. you'll need a 10mm for the bolts, a spark plug socket, maybe a 6" extension.
Old Dec 10, 2004 | 09:06 AM
sentry65's Avatar
sentry65
the burninator
what's a spark plug socket? or what do you mean? like a wrench for it or something to hold the new spark plugs with?
Old Dec 10, 2004 | 09:30 AM
dgz32's Avatar
dgz32
A spark plug socket has a rubber liner inside that holds the plug in the socket for removal and placement. It's also deeper than your average socket.
When I installed my plugs, I didn't remove the strut bar, and only removed the intake tube itself, along with the engine cover. You will definitely need an extension, seems like mine was a 12" - those plugs are down in there. Quite a bit of moving stuff around to get to the coil packs (hoses, wiring, etc.) but all-in-all not a big deal...very easy. Seems like it took me about an hour my first time - start to finish. I've read of other folks doing it in 30 minutes or less. But I'm particular. ;-)
Also, if you don't already have one, get your hands on a good torque wrench - you DO NOT want to over torque any of the bolts or especially the plugs. Do a search for the torque specs (info's kind of scattered around on the site, but it's here). I can't remember exactly what they were and don't want to post any misleading information. Or better yet, buy a service manual.
Anyway, as I said - a very easy DIY.
Have fun!
Dave
Old Dec 10, 2004 | 02:31 PM
mrtomcat's Avatar
mrtomcat
also make sure they new sparkplugs are gabbed correctly and you don't accidently drop them and change the gab
Old Dec 11, 2004 | 04:40 AM
mzack's Avatar
mzack
mdacko. Maybe you could change mine since they are so easy!! just kidding.
Old Dec 11, 2004 | 06:37 AM
westpak's Avatar
westpak
SFZCC
It also helps if you disconnect the brackets that hold the harness in place, for me this made it easier to get the coils out as the harness was in the way on a couple of them.
Old Dec 11, 2004 | 02:06 PM
Sins4u33's Avatar
Sins4u33
how would i go about cleaning my spark plugs?? i haven't done this yet...i guess i will sit down for a day and do this when i get a chance...but is there some special cleaner i should get or what???
Ben
Old Dec 11, 2004 | 06:18 PM
Daniel G's Avatar
Daniel G
I was wondering the same thing. But I'm convinced that if I could change plugs on an LS1, I could change any plugs. Those who have changed plugs on an LS1 know what I mean
burglapfd
Dec 6, 2020 01:04 PM
