My VQS1 (Almost) is on the way...
Old Dec 18, 2004 | 06:29 AM
pimp1911's Avatar
pimp1911
Glad to see a NA project as well. Your car is going to haul a$$
Old Dec 18, 2004 | 07:05 AM
aalzuhair's Avatar
aalzuhair
Originally posted by Z350Lover
nuff,
The motec m600 alone is around 3200 AUS without drive by wire and the cam control modules, if those modules are included, you are lookin at around 4200 aus mark without tuning and wiring up... the whole job is lookin at around 14K AUS or so... and about the wideband o2 sensors, I am not too sure about it, I have a really good engine/motec tuner working on the project at the moment, he will decide it for me. With the current performance mods (with Unichip currently), we pulled out 169.4 rwKW, which is around 230rwhp (aussie rwhp always tends to be lower than those seen in the States somehow).... we are hoping to get around 190 to 200 rwKW with those new mods.... fingers crossed! And if I am not satisfied with the outcome, I will then think about other alternatives later on, which will not be so soon!!!
cheers,
richie
Nice work
Is the motec software easy to use? I'm looking to upgrade from the GReddy e-manage to a stand alone and I was looking at HKS and Motec, but I think I will go with Motec for one reason, which is the ability to tune. So if you please give us more information about the M600 (i.e. why not the m800) and does it come with a base fuel map... and so on
Thank you in advance
Az
PS: Could you please PM me the contact information of the tuner.
Old Dec 18, 2004 | 12:43 PM
Street Visionz, Inc.'s Avatar
wow nice to see another NA project in the works! I was wondering where were you able to purchase all those Nismo S1 parts from and how long was the wait for these parts?
Old Dec 18, 2004 | 12:58 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
x350zx, z1auto.com has some Nismo stuff (low-temp. thermostat, VTC pulley, internals, etc.) you may want to check out.
Old Dec 18, 2004 | 01:21 PM
thanks bro- yeah I've checked out their site a few times but I was wondering where he got his parts from. IIRC, I haven't seen anyone get a set of spec 1 cams yet. Very interested in the results.
Old Dec 18, 2004 | 03:03 PM
Z350Lover's Avatar
Z350Lover
x350Zx:
I got my parts from Apexi Sole Distributor in Australia.... he happens to be my friend and he has quite a lot of contacts in Japan, that's where I got all the parts from.... We were lucky because all the parts (besides S1 cams) were the last set remaining in Japan at that time, we only needed to wait for the production of S1 cams.... took us around 4 weeks or so to get those parts.
cheers,
richie
Old Dec 18, 2004 | 03:11 PM
Z350Lover's Avatar
Z350Lover
aalzuhair:
The engineer who is working on my car is like a father of GTR who is currently working for my friend... he was the head engineer from his racing team back in '90s which raced GTRs here in australia. He is the one who knows what he is doing... There is another alternative that I could go to, that's Simon at Nizpro (www.nizpro.com.au)... they are really good with Motec as well and know the Z very well, but it is just that they will not be available until March or so since they have a huge project undergoing at the moment.
I am not too sure if Motec M600 comes with the base map though... but I doubt so as Motec does not even supply the info on how to connect Drive-By-Wire and the Cam Control Module to Eric (the engineer who is working on my car). Eric needs to wire all the things up himself and also other companies who have done the same things do not want to share the information (since they spent days of work to get those working well together)... That's why it will be quite tough for people who do not know about Motec to do this job.
Also I did not go for M800 is because M600 is exactly the same as M800, the only difference is that M600 only supports 6 injectors and that's what I need.... I don't have a 8 cylinder car to run here and will not want to buy a 8 cylinder car in the future, so M600 is the best choice with its slightly cheaper in price. Hope that answered all your questions!
cheers,
richie
Old Dec 18, 2004 | 04:40 PM
Shift_Daytona Z's Avatar
Shift_Daytona Z
damn I sure am glad its not me wiring all of that **** up!
Old Dec 18, 2004 | 04:47 PM
ALong's Avatar
ALong
Z350Lover,
Why are you still using the stock OEM ECU, with the Motec you dont need it. I am curious to find out why you are still using it.
Old Dec 18, 2004 | 11:07 PM
nuff's Avatar
nuff
ALong, I assume he uses it so it controls ABS, Climate control etc...
Z350Lover, good luck with the project.
Old Dec 19, 2004 | 12:22 AM
Z350Lover: Thanks for the info bro. If you don't mind me asking, how much did you end up paying for the S1 Cams in U.S. dollars?
Old Dec 19, 2004 | 12:26 AM
Z350Lover's Avatar
Z350Lover
nuff:
You are correct there.... I am still using stock ECU to control ABS and the rest of the standard non-engine management functions, otherwise it will be very time consuming to have all the functions in Motec...
cheers,
richie
Old Dec 19, 2004 | 02:52 AM
aalzuhair's Avatar
aalzuhair
aalzuhair:
cheers,
richie
Yes you did Thanks
Old Dec 20, 2004 | 10:29 AM
IceY2K1Max's Avatar
IceY2K1Max
Sweeeeeet~!
So, with the upgraded rod bolts and HD valve springs but stock rods, where are you going to limit max RPM?
Can't wait to see a dyno with the VTC pulleys and an ECU tuned to dial them in.
Old Dec 20, 2004 | 10:35 AM
IceY2K1Max's Avatar
IceY2K1Max
Also, any chance your installer will divulge how to wire the drive-by-wire and cam control modules?
Old Dec 20, 2004 | 02:15 PM
Z350Lover's Avatar
Z350Lover
IceY2K1Max:
I am not too sure about that myself whether or not my installer will share the 2 to 3 weeks of research hardwork with anyone though...
I am going to take the car to 7200rpm as suggested by Nismo (same on the Nismo S-Tune GT's VQ35S1 Engine)... nothing more I would say.... but I heard from Peter who races his 350z in australia saying that those bolts are tough enough to go slightly beyond that... The stock rods can take the stress without any problem according to Peter, so I will not worry too much about that at 7200rpm.
Hopefully we can get the engine out soon sometime this week and get all the things finished by 2nd week of Jan 2005.
cheers,
richie
Old Dec 20, 2004 | 02:38 PM
IceY2K1Max's Avatar
IceY2K1Max
Thanks...I understand the secrecy, but hoped someone would open the door for others.
Anyways, people run 7200rpm with the TS ECUs and stock rod bolts. I know at least one Maxima with ARP rod bolts that plans on a TS ECU with 7500rpm limiter. I'll keep you posted on how it lasts.
If the rods can handle more, then maybe cryo treat the bolts for more strength?
Old Jan 7, 2005 | 12:33 AM
  #38
mchapman's Avatar
mchapman
Hey Richie,
I heard from Peter you were doing these mods, i hope it all goes smoothly.
Those cams should be sweet
Old Jan 7, 2005 | 01:08 AM
  #39
Z350Lover's Avatar
Z350Lover
murray:
Everything goes quite well actually.... the engine is apart already today.... what I could see was all the parts lying on the bench... Will show you guys some updated pics soon!
cheers,
richie
Old Jan 7, 2005 | 01:24 AM
  #40
Z350Lover's Avatar
Z350Lover
Engine Out
