A/F question
Old Dec 24, 2004 | 05:12 AM
kwkslvr's Avatar
kwkslvr
Default A/F question
Please excuse my ignorance, but I have a question on the 350's a/f ratios. I have read that it is tuned fairly lean from the factory, and I am concerned about running the car in a lean state.
My first question concerns my mods and the effect the play on that ratio. I have a JWT pop, Crawford Plenum, Test Pipes,and Borla exhaust should I be concerned, and re-flash the ECU now, or should I just wait until I go FI when I will have to do it anyway.
My second question concerns what role the octane of the fuel will play in the a/f ratio. I am military so I always have 93 octane available. Thanks.
Old Dec 24, 2004 | 07:40 AM
booger's Avatar
booger
I think it depends how long before you go F/I . If its going to be a year...yes I would....I hope they have gotten a little better at the flashed though . My first flash was to rich for N/A ....12.5 A/F ... IMO....As far as your second ? I cant help there...but higher octane never hurts
Old Dec 24, 2004 | 12:49 PM
dynamic6er's Avatar
dynamic6er
Default Re: A/F question
#1 You most likely are not running in a dangerous area, but you do have alot of power left on the table without the flash. We can flash for you. Reflashes are $150. Hope that helps
#2 Octance is a measure of the antiknock properties of gasoline. Lower the octane the more potential for knock. Raise the octance, lower the potential for knock and it offers the ability to run a leaner mixture for more power. NA can always run leaner then FI.
Old Dec 25, 2004 | 01:51 AM
scz's Avatar
scz
I always thought richer=more power. Lean engine=more heat, less fuel. Please rebut this.
Old Dec 25, 2004 | 02:01 AM
ssc's Avatar
ssc
i would reflash if it was going to be awhile before the FI
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
