4th gear around 80mph felt like hitting revlimiter
Old Jan 3, 2005 | 03:23 AM
ttsupra94's Avatar
ttsupra94
Default 4th gear around 80mph felt like hitting revlimiter
I just installed a couple new things this past weekend, hf cats and plenum. Sunday afternoon, i was merging onto the interstate and gunned it. I was going about 40 in 4th and then i gunned it. Next thing i know, it feels like i hit the rev limiter and I shifted to 5th. I thought 4th gear went to a higher speed before hitting the rev limiter, but i can't find info from searching. I didn't notice any other problems. I dont hear any leaks after install and there is no idling problem or loss of power besides this one instance. I might have been going a little more than 80 but i was in the process of merging so i wasn't looking down
I've also read some posts before about maxing out the MAF but i thought that was only with FI.
Any ideas what happened? At about what speed do you hit 6600 rpms in 4th gear?
Old Jan 3, 2005 | 08:19 AM
ttsupra94's Avatar
ttsupra94
bump
Old Jan 3, 2005 | 08:29 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You likely engaged your traction control. Sounds like that is the problem...happpens to me all the time, so in a straight line, I always disengage the TC or VDC
Old Jan 3, 2005 | 11:17 AM
ttsupra94's Avatar
ttsupra94
Traction?? I'm not following GQ, can you explain more. I had VDC on, i never turn it off actually. Are you saying I lost traction at 80mph? I know you know what you are talking about, i'm just not following lol. I've gunned it getting on the interstate before but never felt that. I was pretty sure i didn't hit the rev limiter but just wanted to double check. Thanks for the info guys.
Old Jan 3, 2005 | 11:19 AM
ttsupra94's Avatar
ttsupra94
I dont know if my first post made sense. I went from about 40mph to around 80mph in 4th gear when i felt the "wall".
Old Jan 3, 2005 | 11:31 AM
350zluvr's Avatar
350zluvr
When you hit the rev limiter, the power to the engine is automatically shut off and this is abrupt.
When VDC is on and you lose traction on both wheels, power is shut off in a very similar fashion.
I know you know what both of these systems do and how they work, I just worded it this way purely for comparison's sake.
Does this help?
Old Jan 3, 2005 | 11:34 AM
leemik's Avatar
leemik
it's possible you lost traction.. it happens a lot to me when I least expect it at any speed when flooring it at just the right time.. and now that it's colder out, I lose traction quite frequently with my summer tires and lots of rear camber.. Feels like I'm hitting a wall while accelerating..
Did you see a small light flash on the center instrument cluster? near where the shift light is?
--mike
Old Jan 3, 2005 | 11:38 AM
ttsupra94's Avatar
ttsupra94
Yeah, but there was no loss of traction. I dont have enough power to cause that. Thats why i'm concerned. Although, i guess there could have been some traction loss while merging or maybe hitting a little bump. I can't say i really noticed but i dont know what else would cause that. That does make sense though. I guess i'll have to see if it happens again.
I thought that was what he meant, just never had it happen before so i didn't think it was possible on a straightaway at that high of speed.
Thanks guys, i feel better.
Old Jan 3, 2005 | 12:06 PM
leemik's Avatar
leemik
How do you know you didn't lose traction? You would rarely feel the loss of traction with VDC or TCS on.. what you feel is the car jerking you while you were accelerating.. or the car won't accelerate as fast..
You could have hit a wet patch or something you couldn't see on the road.. the stock tires suck as we all know..
--mike
Old Jan 3, 2005 | 12:13 PM
ttsupra94's Avatar
ttsupra94
You guys are probably right. That is the only thing that makes sense. I dont remember seeing a light flash but i'm sure i could have easily missed it since i wasn't really looking at the dash (i was merging and looking in the mirrors). I just thought it might have been something caused by the install of the plenum so i just wanted to make sure.
Old Jan 7, 2005 | 04:36 PM
tonester1011's Avatar
tonester1011
CF God
this has happened to me also...i was driving down the highway just cruisin and the car just started to slow down like traction control was goin off...i just let off the gas and then went again....didnt even hit any bumps either and road was bone dry
Old Jan 7, 2005 | 05:22 PM
kcobean's Avatar
kcobean
Hey TT, I know what happened, you were going so fast, you sucked the car in front of you right through the filter and into the engine!
Old Jan 7, 2005 | 07:33 PM
ttsupra94's Avatar
ttsupra94
I hope no one else finds out!
Old Jan 7, 2005 | 07:42 PM
Sins4u33's Avatar
Sins4u33
lol this happened to me on the way to work...punched it in 3rd gear...cooking on the straight away....alot of bumps on 370 towards shady grove rd east...and car bounced and lost traction just alittle bit under hard acceleration and TCS came on....it does happen....my rear tires are soo bad now...when its raining and i tap the gas hard in 1st i jump to the rev limiter almost instantly....pretty bad...maybe i should get some new tires??
Ben
sherm
Apr 11, 2020 05:21 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
