Gauge Setups...
well, when i was installing my ati procharger i was sort of stumped to find location for my gauges...i was interested to see where people have mounted there gauges, so post some pics of what you guys got. btw i ended up going with a 2 pillar gauge pod setup. ill see if i can get a pic up eventually..been hell around the shop since the weekend. but please post up some pics im interested to see where people have put there gauges...
Ben Yavari
Altered Atmosphere
Ben Yavari
Altered Atmosphere
Ben Yavari
Altered Atmosphere
Ben Yavari
Altered Atmosphere
3 - Boost , Fuel psi , A/F (LM-1 WB driven) in the A-pilar (triple pod)
3 - EGT , Oil psi , Oil temp) in the NAV pocket
The similar is possible in the Z as well, although you already have an OEM oil psi . The DEFI-Ds match OEM (amber backlit) best.
This is exactly what I've been debating for what seems like forever. Reen used to make a CF plate to fit two 52mm gauges in the NAV, but I guess he doesn't make then any more. If you're in CA like me, then we gotta keep it low key...no pillar. If you get pulled over they may see the ati steering column mounted gauges..I get the feeling it's going to have to be custom...but then there's that Din gauge mount from Defi..maybe?
bcoffee20
Nov 19, 2015 06:39 PM
