I Melted My Dipstick
Old Jan 17, 2005 | 08:59 PM
Barzten1's Avatar
Barzten1
Default I Melted My Dipstick
Kept getting smoked out when I would boost and couldn't figure it out. Turns out crank case pressure pushed out my dipstick a little and the rubber surround on the top of it melted. Has this happened to anybody else?
Old Jan 18, 2005 | 02:26 AM
teh215's Avatar
teh215
Not happening here but, if your crankcase pressure is that high you very well may have severe ring blow-by. I would do a compression test to see if the motor is toast. The PCV system should take care of this in all but the most extreme cases. Good luck.
Old Jan 19, 2005 | 11:28 AM
jpc350z's Avatar
jpc350z
Bartzen,, would appreciate an update on what may be causing the meltdown.. Thanks
Old Jan 19, 2005 | 01:31 PM
dynamic6er's Avatar
dynamic6er
Check to make sure the crank vent hose was rerouted to the intake side of the turbos. If not then your pushing boost into the block.
apex locator
Jul 23, 2021 02:27 AM
Inspatatrac
Sep 8, 2015 02:12 PM
N1-R
Jun 30, 2009 06:35 PM
sifuK
Jul 27, 2003 07:46 PM
