Transmission Gurus question please!
Old Jan 18, 2005 | 05:58 PM
gdwisni's Avatar
gdwisni
Default Transmission Gurus question please!
Ok , here is my question. On an automatic transmission there is a flywheel which bolts directly to the torque convertor. This is considered rotational mass. Would changing the flywheel to a lighter unit have similar effects as swaping out the stock flywheel for a lightened flywheel in a manual transmission. If so is there a special bolt pattern that would be needed to mate with the torque convertor?
Thanks in Advance,
Greg
Old Jan 18, 2005 | 06:04 PM
AmateuRN's Avatar
AmateuRN
Also interrested....
Old Jan 18, 2005 | 06:58 PM
uplz4588's Avatar
uplz4588
i dont think thats a flywheel im pretty sure its called a flexplate.... and no you cant put a lighter one on it
Old Feb 14, 2005 | 10:30 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Old Feb 14, 2005 | 10:34 PM
Blympie's Avatar
Blympie
It usually is called a flexplate. Unless Nismo makes a lighter flexplate dont touch it. Automatics are made to a certain spec. If you want to take off rotating mass take it to someone who builds transmissions..
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
