am i going to run lean
Old Feb 4, 2005 | 05:11 PM
nuni's Avatar
nuni
Default am i going to run lean
with just test pipes on. will i run even more lean with test pipes and spacers. or do u think i will be ok
Old Feb 7, 2005 | 11:07 AM
RCKTDAWG's Avatar
RCKTDAWG
You will run lean in the mid RPM range. Running lean in the high RPM range is what causes damage. Spacers will not affect anything. An ECU re-flash will set proper air/fuel mixtures. Do a search on Technosquare.
apex locator
Jul 23, 2021 02:27 AM
