Wheel hop------>broken r/axle driveshaft!
Old Feb 17, 2005 | 10:49 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally posted by one3502nv
When I broke my CV joint, it was dumping the clutch @5k and hooking up with too much traction on MT E/T Streets... No wheel hop at all... Usually it rips the splines right off inside the hub, but not on my car yet. I know some race teams are having their axles cryo dipped(frozen) to stregnthen them and some are just replacing them with heavier ones...
hmm....well I guess what we can take from all this is that it's GOOD that the halfshafts are the first thing to go in the drivetrain as they are the cheapest and easiest to fix...if the trans or rear ends were grenading it would be a much bigger hassle.
Old Feb 17, 2005 | 03:58 PM
Bahraini350Z's Avatar
Bahraini350Z
Thumbs up FIXED IT
Ok, I went to a scrapyard and found 2 totaled Z32's. And since we use an R200V on our 350z, I took the shaft out of an N/A 300zx and fixed the head(hub side) of a TT300zx and I got the exact shaft as the OEM cost only $200
and here's a pic of my broken shaft
p.s. notice it was broken from the actual shaft, not the joint.
Attached Thumbnails Wheel hop------>broken r/axle driveshaft!-image-190-.jpg
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
