Just installed JWT clutch & flywheel.....
Old Mar 1, 2005 | 11:49 AM
350Z_Redline's Avatar
350Z_Redline
Man these review posts are making me miss my old JWT setup even more . I had the JWT flywheel and JWT Z32 clutch. This was before they made one for the Z33. It felt perfect but I started to hate the sand mixer sound (mostly @ idle) after a while. I ending up getting rid of it when my last tranny went up. The worst thing is the sound that I hated so much with my JWT is also there on my OEM setup but it's slightly quiter . I guess I never noticed it before the upgrade.
Old Mar 1, 2005 | 11:02 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
The only mods I would do if i had to do it all over again...
JWT Pop Charger
Tilton Flywheel & Clutch (Full street)
NISMO Exhaust
UR Crank Pulley
Suspension
Call it a day
Old Mar 3, 2005 | 11:35 PM
Z BOY's Avatar
Z BOY
thanx, zcruzin, for your awesome reviews. i can't begin to tell you how refreshing it is to read posts on this site that are both informative and grammatically correct. quick question: why did you choose the jwt over the nismo clutch?
Old Mar 4, 2005 | 04:09 AM
Z CRUZN's Avatar
Z CRUZN
Thanks Z BOY! Choosing the clutch........to be honest, I chose the JWT only because I was matching it to the JWT flywheel...no other reason. The JWT flywheel will work with the Nismo & is actually a couple lbs. lighter than the JWT clutch. I'm just the kind of guy that likes to match maker-to-maker when doing certain packages - silly, I know....but old habits are hard to break. From what I read, the JWT clutch has a slightly higher clamping force, but that wasn't really a factor in my choosing.
Old Mar 4, 2005 | 10:21 AM
Z BOY's Avatar
Z BOY
would you happen to know off-hand what is the difference in clamping force btwn the nismo and jwt clutches? if its not that big a diff, i'll probably just go with the jwt cuz their company is located here in san diego where i live, and who better to install someone's product than the very company that makes the product, right?
Old Mar 4, 2005 | 11:33 AM
xephiron's Avatar
xephiron
Nismo is rated at 1030 kg clamping force, JWT clutch is rated at 1200 kg. JWT clutch weighs same as stock, 19 lbs I think, and Nismo clutch is about 3 lbs. lighter (16 lbs. I think)
Old Mar 4, 2005 | 12:28 PM
Z CRUZN's Avatar
Z CRUZN
Exactly!
Old Mar 4, 2005 | 12:52 PM
Z BOY's Avatar
Z BOY
thanks, guys.
ps: would either of these not be recommended if i plan to max out my na setup, a la zcruzn and sentry65, and not go FI?
Old Jan 26, 2006 | 04:58 AM
Cambelsoop's Avatar
Cambelsoop
Hey, i just installed the JWT combo, buti got a few questions.
1, should i hear more of a clicking noise when i switch gears? i dont think so but im hearing a little more of a click click as im selecting gears.
2, the "cement truck" noise i olnly hear when i make a turn and get back on the gas very slightly. ne 1 have the same problem?
3, how long is it gonna take for the engagement point of the clutch to change?
Old Jan 26, 2006 | 08:55 AM
barthelb's Avatar
barthelb
Master
1. I don't have any new click click noises. My tranny always did that when I engaged another gear so maybe the sound isn't new.
2. The Truck noise should only happen when your RPM's are 1500 and below in 2nd or higher. And never on turning.
3. The engagement point doesn't change automatically, it didn't for me. You can adjust it or have someone adjust it.
Based on the things you've noticed, i would think that something might not be installed correctly or maybe your just noticing more stuff now that its there.
Old Jan 26, 2006 | 08:58 AM
Cambelsoop's Avatar
Cambelsoop
im thinking i might be too... and the noise is there for me on a turn if in in 2nd or 3rd and my rpms r low... and its loud and annoying? will that be there for ever.. ?
Old Jan 28, 2006 | 01:21 AM
InZomniac's Avatar
InZomniac
Any thoughts on leaving the stock clutch in with the JWT flywheel???
I have the JWT flywheel sitting at home, and I can't decide if I should bother with the clutch or not.
A lot of people say "Might as well do it while you're in there...." but is that the only reason?
I emailed JWT awhile back with this Q and was told that due to what is left out of the equation that makes the JWT lighter you need to use a spung disc (which the factory unit is not). They do not recommend factory style because it allows for less smooth engagement and shock absorbtion. They do sell just the disc alone (minus plate and bearing) for approx $139.00.
