Engine oil (Mobil)
Old Mar 12, 2005 | 10:02 AM
Phaneom's Avatar
Phaneom
Default Engine oil (Mobil)
Does or has anyone ever used Mobil 1 tri synthetic. 15w-50 for high performance engines. I am going to be adding a Vortech, and am wondering if it would be better to use then the normal grade Moble 1.
Available in a 15W-50 grade, Mobil 1® Extended Performance 15W-50's high viscosity provides outstanding performance in high-revving, high-temperature conditions.
The back of the bottle says
*Specifically formulated for high performance engines
*Meets performance of API SL, SH, CF, ACEA A3/B3/B4 and MB 229.1
*Meets Japanese valve train wear requirements
*Provides protection for gasoline, diesel and turbocharged car engines.
*Tri-Synthetic formula helps to extend engine life.
*Excellent cleanliness and wear protection at high operating temperatures (>205 deg. C)
*Pours at -45 deg. C.
*Helps reduce oil consumption
*Compatible with conventional oils.
What do you guys think? It is also the same price as all the other oils.
Old Mar 12, 2005 | 12:43 PM
350Zteve's Avatar
350Zteve
I would recommend you stick with a thinner weight. I would run 5w30 in the winter and 10w30 in the summer
Old Mar 12, 2005 | 01:52 PM
Phaneom's Avatar
Phaneom
I put the Z away for the winter. But I do drive it lots in the summer. Even if Im going to be running a Vortech SC it wouldn't be a good idea to switch to a little higher grade then 10w-30, maybe a 10w-40? What kind of application would you use a 15w-40 in?
Old Mar 12, 2005 | 10:37 PM
n8vz's Avatar
n8vz
if you want to run higher viscosity in your Z, most 40wt oil would be fine. FYI: JDM Nismo Oil for Z33 is a 5W-40 oil. Using Mobil 1 15W-50 would probably be too thick in a Z.
15W-40 oils are mostly HDEO (heavy duty engine oils) for use in trucks.
Old Mar 13, 2005 | 05:12 AM
Phaneom's Avatar
Phaneom
Thanks for the replys
Old Mar 13, 2005 | 07:45 AM
350Zteve's Avatar
350Zteve
Most modern cars use 5w30 because of how percise the modern machining processes are. Modern engines run very tight tolerances on the main and rod bearings. They recommend the thin oil so it can properly lubricate through those small clearances. If you run a much heavier oil, you run the risk of oil being too thick to properly lubricate when the engine is cold.
Old Mar 20, 2005 | 10:36 PM
paso007's Avatar
paso007
Default Mobil 1 15W-50
Im using Mobil 1 15W-50 on my Z. I agree its thick oil and should not be used on a Z. But this all depends on the climate of the area you live in. I am in the desert and in the summer we get 45-50 degrees Celsius. and in winter almost never under 15 degrees Celsius. So this oil vescosity is perfect for both winter and summer!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Nov 9, 2015 11:10 AM
