wheel hop
Old Mar 15, 2005 | 06:43 AM
Road Warrior's Avatar
Road Warrior
Default wheel hop
has anyone come up with a solution to this annoying problem? i get wheel hop even when banging into 2nd after a good launch
Old Mar 15, 2005 | 07:47 AM
enhanced250's Avatar
enhanced250
supposivly an engine damper will reduce it greatly but havent yet tried it myself
Old Mar 15, 2005 | 09:12 AM
Beaker02's Avatar
Beaker02
VDC cures it. LOL.
Old Mar 15, 2005 | 10:28 AM
GoaTSLonG's Avatar
GoaTSLonG
solid tranny mount/ solid subframe bushings
Old Mar 15, 2005 | 10:57 AM
Road Warrior
Originally Posted by Beaker02
VDC cures it. LOL.
true...seriously though, do the solid mounts/dampner effect driving comfort...as in vibrations?
Old Mar 15, 2005 | 02:56 PM
uplz4588's Avatar
uplz4588
i have a stillen damper but i cant install the F&^#ing thing!
Old Mar 15, 2005 | 06:38 PM
bullseye's Avatar
bullseye
I don't mean to be argumentative, but I don't see how an engine damper would reduce wheel hop on a rwd car. Engine dampers and/or poly engine mounts will reduce/eliminate wheel hop on a fwd vehicle, though. Like Goatslong wrote, solid tranny mounts and sub-frame bushings would do the trick. The trade-off, of course, is you're going to feel more vibration every time you replace rubber bushings with poly or steel bushings...
Old Mar 15, 2005 | 06:42 PM
350G's Avatar
350G
I've never had an issue with wheel hop . . . even when I was NA.
Old Mar 16, 2005 | 06:58 AM
Road Warrior
turn of your vdc....j/k
you must not spin your tires....or have excellent throttle control. there is such a fine line from when the tires are losing traction to them going into wheel hop and thats what irritates me. actually, the vdc does work well but to me it slows down the rpms too much and you lose momentum.
those with dampners i would like to know if this really works....don't feel like wasting money something that doesn't work. reducing is one thing...but i am looking for elimination
rw..out all
Old Mar 16, 2005 | 06:59 AM
all_bark's Avatar
all_bark
after I put on the nismo springs I noticed a great reduction in wheel hop. Not gone completely but GREATLY reduced.
Old Mar 16, 2005 | 07:44 AM
Road Warrior
i have aftermarket coilovers...hks ls+....so maybe i can play with the settings and see if i can get somewhere that way...but right now i like the way it rides
Old Mar 16, 2005 | 12:41 PM
350G's Avatar
350G
you must not spin your tires....or have excellent throttle controll
I roast 'em . . . and my main problem lies in fish tailing. I've just never have had an issue with wheel hop. Perhaps its the 10.5" rears (that still don't hold traction)
Old Mar 16, 2005 | 12:58 PM
Road Warrior
the fishtailing, or oversteer can be adjusted through damper settings, sway bars (adjustable even better), and tire pressure. my wheel hop is mainly on launch or 2nd gear spin...but i am also on stock 17's. never thought about the size of the tire being part of the problem so that brings up an interesting point for discussion.
one of these days i will be getting new wheels/tires either 9/10 or 9.5/10.5....that would be nice if that would solve the problem....and give me more incentive for buying them
Old Mar 16, 2005 | 01:49 PM
teh215's Avatar
teh215
I would NEVER use a solid mount on the transmisssion without solid engine mounts. With just solid transmission mounts the engine is still going to want to torque over but, with the transmission solidly mounted, this is going place alot of stress on the bellhousing bolts. Bad idea. Some thing is going to have to give. My 2¢.
Old Mar 16, 2005 | 01:57 PM
350G's Avatar
350G
Just to add to the discussion, my tuner has 9.5" rears (Z of course) and doesn't have any wheel hop issues . . . and he drives like a maniac I have stock suspension and he has Espelir springs (10mm drop). Neither of us have addressed the sway bars yet (we're poor)
G
Old Mar 16, 2005 | 11:27 PM
jreiter's Avatar
jreiter
I also have wheel hop in first gear burn outs, always have. Since I don't want to break anything, I just try to avoid spinning the tires. I'm not a big burnout kind of guy, but I do have to admit that sometimes it would be fun just for the heck of it. You can see my mod list in my sig, but I've tried all sorts of things and still have it:
completely stock everything: wheel hop
Nismo rims with Toyo T1-S tires (275/40/18): wheel hop
Stillen engine torque damper: wheel hop
RSR Ti2000 springs, Koni shocks: wheel hop
I've even tried setting the Konis to different damping levels, and no setting affected it. Don't get me wrong, all of the above mods were *fantastic* mods and each thing had very positive results. It's just that none of them got rid of the wheel hop. (But I didn't actually buy any of those mods to cure wheel hop, so I can't really complain.)
I'm on my way to get my new tires tomorrow (Bridgestone S-03), so we'll see if that makes a difference.
Old Mar 17, 2005 | 04:40 AM
350G's Avatar
350G
Hmmm . . . . Both of us (me and my tuner) run 19s without wheel hop . . . Does anyone with 19s on their Z experience wheel hop? Just trying to narrow down the variables.
G
Old Mar 17, 2005 | 08:04 AM
Road Warrior
i think you might be on to something 350g.....everyone that has the wheelhop regardless of mods to reduce the wheel hop (enginge dampers, springs, coilovers, shock damper settings, etc) has tires smaller than 19's
interested to know how you are burning your tires 350g....i can get wheel hop by just banging into second, its really bad when i'm in first and doing a burn out...which i don't do so often, but it would be nice to eliminate the wheel hop when i feel like spinning my tires
Old Mar 17, 2005 | 09:47 PM
all_bark's Avatar
all_bark
I've got the track rims on the car, they are 18's not 19's.
if you look at the size of the stock springs verses the nismo ones in the rear, you will see what I mean. The Z's stock springs are very skinny compared to the nismo ones. There may be an even better spring out there than the nismo's but they definitely help the hop ALOT.
anyone esle out there have this same result?
Old Mar 18, 2005 | 05:04 AM
350G's Avatar
350G
I've had my 19s for quite some time now (even before my TT setup) and never have experienced the wheel hop with stock suspension. After TT, the roasting progressed into 3rd gear
G
