Highly tuned N/A Zs. What 1/4 mile and 0-60 times are you running
Old Mar 30, 2005 | 09:04 PM
joust75's Avatar
joust75
Originally Posted by orhanz33
am i missing something here?? this is a plenum spacer right?
Yes and it produces just as much HP as the Kinetix and Crawford REPLACEMENT Plenums at aa hundred bux less. (with no strut bar change)
Some guys on the plenum spacer thread really want to get another GB going. If you chime in and get 50 + people AAM might even do it. Definitely the best bang for the buck mod out for the Z!
Old Mar 30, 2005 | 09:14 PM
joust75's Avatar
joust75
Originally Posted by zman1910
The new 911 carerra S is pretty fast. A couple of mags got its 0-60mph in 4.1 sec with the quarter in mid to high 12's. Thats pretty darn fast and you may need to go FI to achieve that on street tires. Its not impossible though...
Yeah but thats 2005 corvette performance (which smoked the 911 in every comparo so far) Point is I Have seen time slips from stock zs running 13.4 1/4 miles with stock (track model tires). That is the best time you will see for a stock Z and similarly 4.1 0 to 60 is the best 0 to 60 time you will see for a new carrera s. More likely are 4.5 to 4.7 0 to 60 times.
Old Mar 31, 2005 | 05:18 AM
zman1910's Avatar
zman1910
Wow someone got 13.4 with a stock track...amazing. Must've had a factory freak. Never seen that in my life at the local drag. Best I've seen is 13.65 down here. On the other hand some dude in a brand spankin new 911 carerra s always shows up completely stock and consistently hits mid 12's around 113 mph. I realize not everyones will be the same, but fairly close. Thats pretty darn good and about a full second quicker than the fastest Z youve seen. I dont know if all of them are like that but still, theyve got to be fairly close, depending on the driver of course. I actually got a chance to meet this guy also and hes just your average mid 50's guy who recently just started coming to the track.(I'm assuming since he got the car)
Old Mar 31, 2005 | 01:26 PM
vitod's Avatar
vitod
Default quick qustion
I've had my z since aug 04' and I really do appreciate all of the information on this site, especially the steps that were outlined for getting ready to upgrade your vehicle. I know that I will not be adding any tt's or sc's to the car or anything else in that price range. Although I am very interested in geting just another little bit of HP. I was looking into upgrading or changing the ECU and its been very difficult to find out; what the cost is, what the best option is, and what the results will be, meaning how much HP will i gain on the dollar? I'am willing to spend (i know its not much) $1,000.00 to $2,000.00 range what could I do for that price and get the most hp.
thank you
Old Mar 31, 2005 | 01:29 PM
zpeed350's Avatar
zpeed350
Yea, the fastest stock Z I have seen on the boards over the last 2 years was a 13.67 or so I believe.
Old Mar 31, 2005 | 01:33 PM
joust75's Avatar
joust75
thank you
Upgrading the ECU is next to worthless on a stock Z.
#1 you cant simply put in a "chip" You have to have your current ECU reflashed.
#2 The ECU flash on a stock Z gives you 2-3 HP. The upgrade is better when you have mods. In this case the ecu is told how to make best use of the mods.
Old Mar 31, 2005 | 08:13 PM
Armitage's Avatar
Armitage
thank you
Intake, header, and exhaust and test-pips or high-flow cats should cost you around $2k. Reflash after that and your probably looking at at least a 20-30 whp gain.
Old Apr 1, 2005 | 05:42 AM
vitod's Avatar
vitod
Default thank you
this info is very helpful i'm quite new to upgrading thank you. couple more questions if you don't mind. I was thinking of a plenum and i don't fully understand the "final drive" in 6 or 5. is it just changing the gearing and will it help me on my main objective which is to shave off .5 secs on 1/4 mile?
thank you
Old Apr 1, 2005 | 06:13 AM
zillinois's Avatar
zillinois
thank you
In order to get the most out of the 3.9 in the 1/4 mile, you will also need stickier tires. The 3.9 w/ some drag radials should easily take .5-.7 seconds off.
Old Apr 1, 2005 | 08:24 AM
xephiron's Avatar
xephiron
I assume "track model tires" means DR's or something. stock track model 350z running 13.4 on stock 245/45r18 RE040's just seems... impossible.
Define stock, once I saw a guy run 12.4 in what he called a stock eclipse turbo... he meant that the engine and turbo were stock, but he had the turbo cranked up and the car severely stripped down, severely.
Old Apr 1, 2005 | 12:57 PM
Armitage's Avatar
Armitage
True, true.
Old Apr 4, 2005 | 05:31 AM
vitod's Avatar
vitod
Default purchasing my first mods, ever on any car, little help please
I wanted to get started by purchasing a plenum, intake and maybe the pulleys, unless there is something else i should start with. Does anyone have any suggestions on what brands are reputable.
Thank you.
base model 350z
Chris350z03
Oct 8, 2023 07:19 PM
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
FromGtoZ
Sep 20, 2015 03:41 PM
