I am in COMPLETE AND TOTAL DISBELIEF!!!
Old Apr 8, 2005 | 11:05 PM
speedd3mon's Avatar
speedd3mon
Originally Posted by Zivman
Guys at the shop where I dyno'd said they will make you loose power if anything. Seriously! Said something about a closed grounding loop or something and were completely serious about it.
i think that guy was full of it. for one, grounding kits only enhances the stability of the electrical units that control the car (most important IMO is the ECU). It creates better current flow to the negative terminal in your car battery, causing smaller spikes in the electrical units. From my experiences working with chipsets( Im an Electrical Engineer), I find that grounding almost always makes the difference in the world when it comes to performance. Installing a grounding kit will not hurt your car's performance, it could only help. If you have a meter, measure the resistance (OHM) from your VQ to your battery. I read 5 ohms before the grounding kit, and .05ohms afterward. I dont want to bore you with technicality. just get a 4gauge grounding kit, itll help the electricals in the car enormously. My 2 pennies.
Old Apr 9, 2005 | 06:00 AM
xephiron's Avatar
xephiron
+1 speedd3mon:
Yep it's a no brainer, if the stock grounding system isn't up to par, adding a kit can only help. Will you see dyno results? doubt it. Will you drop your 1/4 mile eta, or add to your trap? doubt it. But the car should run smoother, more efficiently, and really it is a bit of insurance to make sure everything is safe.
I have been an electronic tech. for 11 years myself, and 5 ohms between the battery and chassis/engine is horrible. And like he said, don't use little wire the gauge has to be appropriate for the current application, 4 gauge does seem to be the norm with aftermarket kits.
Old Apr 9, 2005 | 09:32 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sun Automobile now makes a kit specifically for the Z called Cyberspeed. Check it out
Old Apr 9, 2005 | 09:39 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep..we are doing it and the hyper voltage kit on Kwame's car next week
Old Apr 12, 2005 | 08:40 PM
TXSTYLE's Avatar
TXSTYLE
Thumbs up
Grounding Kits are the shiz!!! Hell... I even had one made for my Lawn Mower!
Old Apr 13, 2005 | 03:20 PM
spf4000's Avatar
spf4000
I can't tell the difference with mine. Maybe I should try taking it off to see if I can notice a difference.
Old Apr 13, 2005 | 03:27 PM
speedd3mon's Avatar
speedd3mon
"Experience is a dear teacher, and only fools will learn from no other." hahaha! Man you must have time to waste
Old Apr 15, 2005 | 03:19 PM
knight_white99's Avatar
knight_white99
I originally bought a cheaper 8 gauge kit (similar to the one in the pictures posted by DayBlueZ). I really didn't notice much difference. Then I bought a 4 gauge kit. You can get them on eBay for around $40. Wow. The engine idles so smoothly you hardly even know its running. Does it make power? Most magazine tests bear this out. (My Z now makes 260hp at the wheels with 3 simple bolt-ons). I'm happy with the results of the 4 gauge kit. It looks cool, too.
Old Apr 15, 2005 | 03:56 PM
Z1 Performance
Former Sponsor
knight white - that has to be the highest dyno ever for those 3 power mods (unless it's an 05?), but I digress
I swapped the other night from the insane.... (I forget the name of the brand) to the HKS Circle Earth I have had at the shop for eons. I ended up playing with a bunch of different locations, as well as hooking it up slightly different than the HKS instructions, and netted an idle that is now far more stable, as well as a bit of extra punch down low.
adam
Old Apr 15, 2005 | 06:19 PM
RSXPLAYA's Avatar
RSXPLAYA
I just bought the stillen kit from performance nissan. nice kit, difference? I cant really tell. Before the kit my idle used to be smooth and once in a while it would bounce, it still does the same thing after the kit. It does look nice though
Depravity
Oct 1, 2015 04:49 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
