Stillen engine damper install
Old Apr 6, 2005 | 03:32 PM
Hammerman's Avatar
Hammerman
Got twisties?
Question Stillen engine damper install
Question for those few who have purchased and installed the Stillen engine damper: how the heck did you tighten the #$%^&*! assembly on the end of the damper that attaches to the frame rail?
I'm not referring to the three bolts that secure the bracket to the frame rail; rather, I'm referring to the bolt and nut that pass through the damper bracket horizontally and secure the damper to the bracket. I can barely shove an allen wrench into the bolt end, but I can't fit a socket wrench on the nut. And there's no room to pivot a crescent wrench.
Any help or suggetions appreciated. Anyone? Bueller? Anyone? Anyone?
Old Apr 6, 2005 | 03:47 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
When I had mine done, we completely took off the coolant bottle to make space. Made it real easy to do the install in that tight area.
Old Apr 6, 2005 | 03:48 PM
mofoz's Avatar
mofoz
CJM(phunk) did mine and they said they fought with it but had to take the bottle off to get it tightened.
bill
Old Apr 6, 2005 | 05:30 PM
uplz4588's Avatar
uplz4588
yeah just remove that coolent bottle its like 1 bolt... that way you will have enough room... we had to take a long a$$ chizle thing to spread the bracket out a bit, then it slid in and we had 2 socket wrenches... i held one in place and tightend w/ the otherone
Old Apr 6, 2005 | 07:07 PM
copba1t's Avatar
copba1t
A box wrench did the trick for me
Old Apr 6, 2005 | 08:15 PM
Hammerman's Avatar
Hammerman
Got twisties?
Thanks for the replies.
It's all about having the right tools, isn't it? I don't have a box wrench set but I'll go grab one...they look like they would be quite handy for several jobs.
And I'll remove than damn coolant bottle too...I almost did that before I got started because it seemed to be in the way of everything.
Old Apr 8, 2005 | 02:11 AM
jreiter's Avatar
jreiter
You can also pick up a ratcheting box end wrench. Even better. But you said it, it's all about the right tools with some of these tight spaces. Like doing the tranny install: a 3 foot extension for your ratchet makes all the difference.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
