My Dyno
Old Apr 22, 2005 | 04:42 AM
Bick350Z's Avatar
Bick350Z
Originally Posted by DomZ
What gear is closest to 1:1 in a 5AT...4th?
And shouldn't those numbers be SAE corrected?
yea, 4th on 5AT and 5th on 6MT
Old Apr 23, 2005 | 01:18 PM
PoWeRtRiP's Avatar
PoWeRtRiP
Originally Posted by Armitage
Yes but nearly 11 at redline is stupid rich. Keep it between 12.5-13.0 and your golden.
on an n/a z anything under 14:1 that makes good power without knock should be alright. generally leaner a/f makes more power.
Old Apr 23, 2005 | 03:06 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
Hi, first off I"ll just mention I'm not a tuner. Our tuner is out in Nevada delivering a car today so I didn't have a chance to ask him to look at your graph.
Based on your graph it looks like you're detonating heavily up top or your car was slipping on the rollers. What modifications do you have? Did you try pulls in any other gear?
Can't say much for the resolution of dynojets, but for the torque to drop off sharply after 5K is pretty strange and maybe indicitive of ecu dumping fuel and pulling timing. The 3 dips that you see up top may also be timing adjustments, although they are usually more pronounced.
As for the A/F, your car is running fairly lean in the midrange. IMO a good safe A/F for the 350Z should be in the 12-12.5 to 1 range. The VQ35 is a strong engine (NA), the ECU is fairly responsive to detonation therefore a lot of guys tuning it into the 13:1+ range is still able to run for many miles. However, this is fairly lean, even for a non-turbo car and is a risk because of the varying conditions a car will encounter.
Our target A/F for STI's is 11:1 and EVO's is 11.2:1. The stock A/F on these cars is around 10-10.5. We've repaired a number of cars that have run for over 30K miles at 13:1 (as a result of bad tuning) and the owners were not even aware of a problem. Generally speaking on a 13:1 A/F car on a Subaru will tend to eat up spark plugs and coil packs, and will generally leak down at a lot lower compression than a car that has been properly tuned. But the owners often don't notice.
What I"m trying to say here guys, is please be err on the side of safety while tuning your car.
Cheers,
Gary
Gruppe-S
Old Apr 24, 2005 | 04:36 AM
PoWeRtRiP's Avatar
PoWeRtRiP
Cheers,
Gary
Gruppe-S
your right you are very careful. an evo runs great between 11.8-12.2:1. an 11.2:1 will cost us a lot of hp.
Old Apr 24, 2005 | 10:25 PM
Gruppe-S's Avatar
Gruppe-S
California 91 octane pump does wonders to promote detonation...
Cheers,
Gary
Gruppe-S
Old Apr 25, 2005 | 03:43 AM
Bick350Z's Avatar
Bick350Z
Thanks for the responses guys. I havent done anything to my car since the dyno. Should I take the car to the dealer and have them take a look at it? I do use 91 on my car. The only thing I have done to the car is Nismo Intake. I bought the car with that mod.
Old Apr 25, 2005 | 04:49 AM
PoWeRtRiP's Avatar
PoWeRtRiP
Cheers,
Gary
Gruppe-S
LOL i forgot about that 91 over on the left coast. we can get 94 at some stations here.
Old Apr 25, 2005 | 05:02 AM
zmespeed's Avatar
zmespeed
Originally Posted by Bick350Z
I dont know how I would correct the AIR/FUEL issue, perhaps a mechanic? I also have 28K miles on the car. I might have to clean the filter, i have no idea when it was last cleaned.
in 2,ooo miles you due for a regular maitnance. could be the differance of 5hp. but when i got my car back it felt slower. i think its becuse the bastards at the dealershit took out my k&n and put in a stock. i bought the car used and i just thought the stock filter was orange. but now ive got some crap wight one.
Old Apr 27, 2005 | 03:34 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
My opinion? Either one of the following is the problem:
1. MAF sensor problem (oil from filter is common)
2. Dirty or clogged intake filter/tube
3. Wideband probe @ the dyno isn't tuned/needs replacing/etc.
That AF ratio is silly for a stock ECU. I'd recheck the intake install and then get a wideband done at another dyno as the first troubleshooting step.
If you're ever near LA, I'll meet up and run some codes off your OBD to check your sensors if you want (intake temp, narrowband, timing, etc.)
Old Apr 27, 2005 | 04:41 PM
Bick350Z's Avatar
Bick350Z
Thanks for the reply zxsaint, i live in san diego and would not have a problem driving to L.A for some help. Maybe we can schedule a time to meet up. Let me know.
A.J.
Old Apr 27, 2005 | 07:37 PM
JamRWS6's Avatar
JamRWS6
Originally Posted by Lorca@Z1
1:1 gear ratio is 5th gear, 4th gear would not be an accurate measurement.
Here is an example of what I was talking about. These runs were made within a 7 minute time span and there was 5 minutes between Run #1 and Run #4, with 4 through 7 being within 2-3 minutes total.
This was on a G35C with a Tilton clutch and flywheel and CAI.
Do you have the corresponding A/F ratio graph that would go along with those pulls? I think it would be interesting to see if the A/F ratio varied on those pulls.
Old Apr 27, 2005 | 08:14 PM
Bick350Z's Avatar
Bick350Z
I wish I did, for 2 pulls it cost me $100. Fockin cork soakers.
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
