Zeitronix TPS hookup.
Old May 3, 2005 | 11:04 AM
BPL's Avatar
BPL
Default Zeitronix TPS hookup.
I'd like to hook up the TPS input on my Zeitronix for datalogging. From checking the service manual, I see that there is a TPS1 and a TPS2. anyone know which line I should use?
Old May 4, 2005 | 10:48 AM
BPL's Avatar
BPL
Ok, got the answer from Zeitronix. TPS is the one to use in case anyone else needs to know.
Old May 4, 2005 | 10:57 AM
kopo's Avatar
kopo
Can you post more details about hooking this up..im a total newb when it comes to this
Old May 4, 2005 | 01:33 PM
BPL's Avatar
BPL
Actually I meant to say TPS1 is the one to use. There are two throttle position sensors but the Zeitronix only has one input. You want to use the TPS1 input to the ECU when datalogging throttle position with the Zeitronix. TPS1 is pin 50 on the ECU wiring harness in case you don't have the shop manual.
Bassmaster
Feb 25, 2007 06:31 AM
Phatmitzu
Jun 22, 2004 09:30 PM
onecoolee
Jun 21, 2004 02:57 PM
CaneZMD
May 22, 2004 12:16 AM
