what to do next..
Old May 6, 2005 | 08:14 PM
itsjoshufocker's Avatar
itsjoshufocker
Default what to do next..
right now i have about $2200 dollars to spend on my Z.. im about to drop $1600 on some rims... so that leaves me with another $600 to use up.. i already have a CAI and evo 2 exhaust.. what do yall suggest next? im thinking HFC or test pipes.. but afraid of getting pulled over for test pipes.. any ideas for what i could do to make a Z have a littler more power?
Old May 6, 2005 | 08:28 PM
harrieyu's Avatar
harrieyu
plemu, spacer and test pipes and then ecu reflash
Old May 6, 2005 | 09:01 PM
DayBlueZ's Avatar
DayBlueZ
Plenum spacer and UR pulley set
Old May 6, 2005 | 09:11 PM
Z'd Up's Avatar
Z'd Up
Hotchkis sways and springs for handling/performance
Plenum spacer complete what your CAI is essentially trying to do
You may have some money left for some wheel locks....
you can do the HFC and test pipes later... good luck with whatever you decide
Old May 6, 2005 | 11:02 PM
ReavTek's Avatar
ReavTek
UR Lightweight Pulleys provide a noticiable increase in acceleration. It is one of the best NA mods you can get, bang for the buck wise.
Old May 6, 2005 | 11:42 PM
phunk's Avatar
phunk
CJ Motorsports
i would start with some tires to put on your new wheels.
Old May 6, 2005 | 11:44 PM
Z BOY's Avatar
Z BOY
spacer and hfc
Old May 7, 2005 | 12:49 AM
dan-14's Avatar
dan-14
+1
Old May 7, 2005 | 05:15 AM
zachcrosen's Avatar
zachcrosen
Kinetix HFCs or test pipes and the Kinetix v4 plenum. Both will be $650 shipped to your door! Or maybe something else here:
https://my350z.com/forum/intake-exhaust/120390-kinetix-gb-all-products-except-y-pipe.html
Old May 7, 2005 | 07:48 AM
itsjoshufocker
$1600 for rims *and tires... can you guys andwer me something... if you put..lets say.. 2 1/2 inch spacers on top of each other, will it give you an even bigger amout of whp? maybe not a lot.. but at least 5 or 6 more?
Old May 7, 2005 | 08:43 AM
Machupo's Avatar
Machupo
doubt it -- if i had $600 and was starting where you are, i would pick up some cheap resonated test pipes, a plenum spacer, and a U/R crank pulley
Old May 7, 2005 | 12:16 PM
DayBlueZ's Avatar
DayBlueZ
If you wanted to do that, go with a new Tall Plenum. But, you will have to change the strut bar and probably the hood to do it. Going to be more than 600 yankee dollars. You can get 5-6 out of the UR pulley set.
http://www.************************/35...num/plenum.htm
Old May 7, 2005 | 02:56 PM
Z BOY's Avatar
Z BOY
don't put anything cheap on your z, and a pulley will void your warranty.
Old May 7, 2005 | 03:01 PM
Machupo's Avatar
Machupo
ok, agree with the cheap part, but the U/R pulley will not kill your warranty -- the dealer must prove that your part caused the damage in order to not cover the repairs under warranty.
i had the dealer put the pullies on 8 months ago, and i've been in half a dozen times for warranty fixes with no problems
Old May 7, 2005 | 03:04 PM
Z BOY's Avatar
Z BOY
i'm just repeating what the nissan rep told die die when he came to the dealership to oversee die die's tranny replacemnt.
leemik
Apr 7, 2010 11:09 PM
redline350ZZ
May 30, 2007 06:35 PM
