JWT clutch/flywheel install
Old May 12, 2005 | 03:44 PM
dollar99's Avatar
dollar99
Default JWT clutch/flywheel install
Okay, I just recieved my clutch/flywheel combo. I was told by the vendor that it came with a throwout bearing and alignment tool. Well, it didn't so now I'm stuck cause I was supposed to get this thing installed tomorow. My question is, does the jwt clutch use the OEM throwout bearing? and do I need an alignment tool to install, if so, where can I get one? THanks in advance for your response.
Old May 12, 2005 | 05:13 PM
lovetoclown's Avatar
lovetoclown
You can use your stock throw out bearing and you do not need an alignment tool. You can also re-use all the bolts. but it is better to use new clutch bolts and flywheel bolts.
Old May 13, 2005 | 03:43 PM
jreiter's Avatar
jreiter
Yup, we re-used the stock throwout bearing on mine, and didn't use an alignment tool.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
