Guess what arrived today!
Old May 12, 2005 | 04:41 PM
Machupo's Avatar
Machupo
Default Guess what arrived today!
Old May 12, 2005 | 04:44 PM
manofsteele2003's Avatar
manofsteele2003
Hmmmm....camshafts?
Old May 12, 2005 | 04:45 PM
MIAPLAYA's Avatar
MIAPLAYA
Looks like Tomei cams to me....
Glasgow Smile's Avatar
Glasgow Smile
dat title
Tomei cams?
I believe that's the word Tomai blurred on the right.
[Beat me to it Mia]
zand02max's Avatar
zand02max
Your Syphllis test results are back,
Old May 12, 2005 | 04:54 PM
Machupo's Avatar
Machupo
bahahaha, yep -- big tubes of syphillis-laden growth
yep -- you guys are right, the tomeis arrived via airmail today -- first package i've ever received from japan, pretty neat!
Old May 12, 2005 | 04:56 PM
Machupo's Avatar
Machupo
i'm hoping they'll be pretty nice, had to go back almost until jan, 2004 in the search to find any threads about them
Old May 12, 2005 | 07:25 PM
pimp1911's Avatar
pimp1911
Specs? Lift and duration.
Old May 12, 2005 | 07:37 PM
ReavTek's Avatar
ReavTek
Those are Tomei 268 cams. Very impressive, what additional parts do you need to run these cams reliably? What is your performance mod list if you dont mind sharing? Oh and how much were they?
Old May 12, 2005 | 09:27 PM
Skrill's Avatar
Skrill
What is the install going to run? Install cost is holding me back from doing cams.
Old May 13, 2005 | 03:05 AM
Machupo's Avatar
Machupo
here's the info site @ Z1Auto:
http://www.z1auto.com/prodmore.asp?m...ine&prodid=521
I also got Nismo high-lift springs with them (apparently, the tomei springs are just rebadged Nismos)... my engine builder will have to spec the lifters once we get going on the build (i'll have to buy those then). Kind of expensive, but I paid $1800 for the cams, the nismo springs, and express air-mail from japan.
Current mod list:
Tilton FW/C
350evo 3.917 R&P
Cusco RS LSD
U/R pulley set
jwt pop charger
crawford cast plenum
ultimate racing cats
nismo exhaust
HP+ pads, SS lines, ATE fluid
I'm doing the install at the same time I'm building the bottom end of the engine, so it shouldn't be much additional maybe a couple hundred bux. If you do them on their own, expect about 8-10hrs. ($600 at my shop) in labor.
Cams are going in with the pauter rods, arias pistons, ARP hardware, and the ATS clutch/flywheel -- looking at a greddy kit w/ the additional safety bits (baffled & oversize oil pan, shielded CAS wire, return fuel system, etc...)
Old May 13, 2005 | 05:42 AM
mcduck's Avatar
mcduck
It will be interesting to see how these cams do with FI when you go that way. Typically, an aggresive NA grind is not very FI friendly. My bet is you would have been better off with the Tomeis that are a step or two down from thesefor an FI build. For built NA, the 268s should be great, tho!
Old May 13, 2005 | 06:56 AM
Machupo's Avatar
Machupo
yeah the reason that I got them is that they've got equal intake and exhaust durations, which should bode well for FI applications -- but the proof is in the pudding so to say
it's going to be a bit before i can get them installed, but i just couldn't resist posting something (trying to get some feedback on others who may have them)
Old May 13, 2005 | 08:56 AM
G3po's Avatar
G3po
Default Lsd
Machupo:
I noted you have a Cusco RS LSD.
How do you like it.
How noisey is it for street driving?
What setting are you at?
What fluid do you run?
I'm considering wither this LSD or the new ATS carbon.
Old May 13, 2005 | 09:17 AM
Machupo's Avatar
Machupo
Originally Posted by G3po
Machupo:
How do you like it.
The first time I hopped in the car with it and drove around, it was noisy as heck (clunk clunk clunk), but after doing about 50 figure 8's in a parking lot, going back and swapping the fluid, it quieted down quite a bit -- it's on 2-way right now and I run Redline MT-90 in it. You'll only really notice the clunking at low speeds going around sharp corners (or if you're creeping in a parking lot). Of course, with the tilton already on there, it isn't much of an increase in noise
I personally love it -- even with the VLSD, my Z's *** end was always kicking out under hard acceleration and the steering didn't inspire confidence in hard turns, but it's all great now
Old May 13, 2005 | 12:36 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Curious..how long was the wait for the Tomei..I have been quoted 10-16 weeks.
Old May 13, 2005 | 01:11 PM
Machupo's Avatar
Machupo
paid an extra 8000Y and it was here in 10 days (minus the 7 days for "Golden Week" since no one was at work)
Old May 13, 2005 | 03:07 PM
G3po's Avatar
G3po
Cool, what's your lock-up %. 60% , 100% ??
Old May 13, 2005 | 03:44 PM
Machupo's Avatar
Machupo
whatever it came stock -- 350evo assembled it for me
Old May 13, 2005 | 09:03 PM
Sharif@Forged
Forged Performance
not bad for about $70 extra.
