What shops install cams in L.A. (Cali) and how much do they charge??
Old May 13, 2005 | 01:00 PM
Skrill's Avatar
Skrill
Default What shops install cams in L.A. (Cali) and how much do they charge??
Inquiring minds want to know.
Old May 13, 2005 | 05:41 PM
350Zteve's Avatar
350Zteve
There's always Performance Nissan in Duarte
Old May 13, 2005 | 06:06 PM
HarvesterUT's Avatar
HarvesterUT
i have "heard" (ie read on here) that the cam install is about a 12 hour deal.
about $1000 id guess
Old May 13, 2005 | 08:05 PM
NOBI's Avatar
NOBI
Brainstorm on washington in LA
Old May 13, 2005 | 08:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
it's one of the most expensive labor jobs for the 350Z. You need to remove all the accessories, the front and rear timing cover, sprockets, timing chain, all the hardware. It's a flipping mess. My guess is at least $1200
Old May 13, 2005 | 09:41 PM
Z BOY's Avatar
Z BOY
thank god my oil was burning...free labor for nismo cams, clutch/fw, high strength cr bolts install!!!
Old May 14, 2005 | 06:02 AM
xziteme's Avatar
xziteme
Sorry to hijack the thread, but how do you know if you have oil burning issues?
Old May 14, 2005 | 09:59 AM
ssc's Avatar
ssc
damn, ~1200+cost of cams!...that is so not worth the minimal gains, imo
Old May 14, 2005 | 10:03 AM
HarvesterUT
minimal gains? some cams are getting 8-10whp through most of the band depending on the lift/dur. thats not bad for $2000. consider some exhaust/header combos get about that for roughly the same price.
Old May 14, 2005 | 11:06 AM
jlimquest's Avatar
jlimquest
Contact Street Image (Eric) in Baldwin Park for the install (626-962-1503).
Old May 14, 2005 | 11:50 AM
Z BOY's Avatar
Z BOY
read here:
https://my350z.com/forum/showthread.php?t=121915
Old May 14, 2005 | 12:07 PM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
I'm willing to give you a hand if you have a spare car in case we don't finish on time. I'm assuming we don't need to pull the motor just front bumper off.
Old May 14, 2005 | 01:57 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
We no longer install the cams here, since they are not smog legal. You can contact us for more info and details however. Also, SP engineering can most likely do it, they are a bit pricy but they are top notch, you won't be able to find a better place for tuning than SP.
Old May 14, 2005 | 03:24 PM
HankVQ's Avatar
HankVQ
Hey Tony I know cams are not smog legal but what type of effect would say the Nismo cams have on Cali. smog testing. I am considering adding cams and am wondering if it would have a negetive effect making it tough to pass.
Old May 14, 2005 | 05:34 PM
Skrill's Avatar
Skrill
I have a spare car (actually, the Z is my spare car) ... do you have a shop?
Old May 16, 2005 | 02:21 AM
Tenac1ousZ's Avatar
Tenac1ousZ
For those of you with Nismo or other Cams, did your engine loose a lot of torque in the 2-4k RPM range? And How much HP did your engine gain overall, and what is the power band like?
I'm thinking of adding Nismo cams for better engine responce in the higher RPM range -- kind of like the '05 track's power band. (don't mean to jack your thread...lol)
Vince
Old May 16, 2005 | 06:29 AM
Tony@Performance
The cams will probably play in a negative way when it comes to cali smog testing, however I've never seen a z with cams do a test before to know 100%. You may scrape by, but i think that it will probably be worse in the lower rpms on the test.
Old May 18, 2005 | 02:56 PM
SP_ENGINEERING's Avatar
SP_ENGINEERING
Default cam installation/tuning
we can do it we can do it!
Old May 18, 2005 | 06:48 PM
LaoSiFu's Avatar
LaoSiFu
I am sure you can, I would recommend SP to do it. They're pretty much legends here in southern california.
Old May 19, 2005 | 03:09 PM
Skrill's Avatar
Skrill
PM me -- do you all have an email address or someway I can get ahold of you?
