Horse power check, approximate hp from these mods...
Old May 15, 2005 | 09:06 AM
bstfugtfomrfn's Avatar
bstfugtfomrfn
Default Horse power check, approximate hp from these mods...
I have a 2003 track 6mt.
UR crank pulley - (supposedly anywhere from 6-12 hp)
borla true duels - (not really sure, ive read around 13hp)
meghan test pipes - (no idea)
jwt pop charger - (states around 6hp)
aam angled plenum spacer - (states around 9-11hp)
Now assuming my stock numbers are what we are told they are, what type of numbers can i expect at rwhp or at the crank? Now I know I can simply add the approximate numbers, but I was wondering if anyone has taken their similalry modded Z to a shop and ran it on the Dyno.
Anyone with a Z similarly modified?
PS. What type of hp does a nismo wing, and grounding kit add. Im also looking at maybe adding a nismo gas cap...(12hp ive heard!!1!11oneone!!) j/k
~AJ.
Old May 15, 2005 | 01:04 PM
Jaki's Avatar
Jaki
My guess would be around 20rwhp. I've seen different Z's get different hp with the same parts... but 20 seems reasonable.
Old May 15, 2005 | 01:16 PM
sentry65's Avatar
sentry65
the burninator
yeah probably around a 15-25 whp increase depending on the dyno/location/fuel octane you run
it would be awesome if hp gains were 1+1=2 math, but they're not
Old May 15, 2005 | 03:38 PM
Speedracer's Avatar
Speedracer
Realistically.....10-15hp with everything. Add headers and you're talking 20-22hp. Add cams on top of that with an ECU reflash and you'll be up to about 30hp with 93 octane or higher gasoline.
Old May 15, 2005 | 06:10 PM
bstfugtfomrfn
flash was next. As it was economically friendliest. We'll see, thanks for the input fellas.
~AJ
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
