dyno #'s no ecu tuning basic bolt ons
Old May 25, 2005 | 02:44 PM
copba1t's Avatar
copba1t
Yea, one dyno in and of itself don't really mean much at all. It's just numbers on a piece of paper. In addition, trying to compare different dynos from different cars is just about as pointless. Take her to the track =)
Old May 25, 2005 | 03:45 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
Potential causes of low #'s in this case
1. Dirty Intake Filter (11.9 AF @ 6100rpm)
2. Heat soak (Temperature of runs)
3. Rotational weight - What wheels/tires you on?
4. Timing retard due to knock
Old May 26, 2005 | 12:09 AM
GTO2350's Avatar
GTO2350
1.my intake maybe dirty shouldve cleaned that
2.It was a pretty hot socal day 88degree F. drive took about 30min's and went straight on the dyno when i got there.
3. 5zigen fno1rc's lighter than stock rims tire sizes are 235/255
4.How can i tell im knocking? when SAFC II was on showed knock but may of not been calibrated correctly. Wouldn't i be able to feel like hesitation of some sort with timing retard?
thanks on the constructive info
Old May 26, 2005 | 07:39 AM
Zquicksilver's Avatar
Zquicksilver
Originally Posted by DrVolkl
Yeah, that makes sense to me. Get the ECU asap and see if the #'s jump...because right now I don't think the headers are helping at all.
I'm curious to see what sort of gains you get. I also would like to see what sort of gains I would get if I reflash mine as well...might not be much at all.
Ahhhh, the quirky little Z
After I install my HF cats and Headers, I'm taking it to a dyno to check my a/f mixture. If I'm fine and the results are good, I obviously won't be dropping $600 bucks. But if I'm not, then I will post the before and after charts as a result of the reflash. Hopefully I get lucky!
Zquicksilver
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
