4k to spend
Old May 27, 2005 | 12:56 AM
themartyr's Avatar
themartyr
Default 4k to spend
I want to stay NA. What should i get and whats the suggested hp. with the mods. Thanks to all.
Old May 27, 2005 | 03:58 AM
zillinois's Avatar
zillinois
3.9 final drive $850
ATS Carbon LSD $1000
Test/Cat Pipes $500
Tilton Clutch/Flywheel $1000
With install should put you around 4k. Your car would be transformed. Really don't get a lot of hp, but your et will go down into the low 13's easy. Lots of other ways to go too, but those are my recommendations.
Old May 27, 2005 | 04:34 AM
seanrulz's Avatar
seanrulz
Spend on bolt on mods.
Invidia G200 Exhaust: $900
Helix HF Cat: $470
KJR Pulley: $170
Motordyne Spacer: $170
JWT Popcharger: $120
Alphawerks Header: $670
JWT Clutch/Flywheel: $810
Install: $1000? (estimate)
Total comes at about $4200. And you are looking at around.. 260rwhp. (another estimate)
Then next step could be cams and ECU reflash. They are gonna cost another $3k. (Install for Cams are a b!tch)
Old May 27, 2005 | 05:51 AM
Sins4u33's Avatar
Sins4u33
you could try the AAM Spec HP Stages
-Ben Y
Old May 27, 2005 | 06:22 AM
VR3's Avatar
VR3
Test/Cat Pipes $500
This will be the route I will go if I don’t go FI..+plenum & cams and JWT instead of Tilton.
Old May 27, 2005 | 10:06 AM
GTO2350's Avatar
GTO2350
i have all the bolt on's except for cams and TS ECU flash and my thoughts are
CAMS: not worth the money you pay for the gains you get i.e (socal dyno day jeff performance 262rwhpw/cams zx saintw/o cams 256rwhp)
TS ECU Flah: IMO you won't see the maximum gains from your mods w/o this.
if i had $4200 i would go with what zillinois recommended after this your car will be an ACCELERATION MONSTER!!!
tilton flywheel/clutch street
evo350 3.9 final drive
JWT intake
Crawford Plenum & Cats.
Old May 27, 2005 | 02:06 PM
Enron Exec's Avatar
Enron Exec
Tomei 264 cams, Injen SES exhaust, test pipes, ECU reflash with higher fuel cut off. Go with more aggresive cams if you can stand a 1000+ rpm idle. These mods have fewer drawbacks IMO then most others. A lighter flywheel, and shorter final drive will put more of the power to the wheels but they dont really make more power out of the motor, plus they have some small drawbacks. Modding the heads, cams, and tunning is where real NA power is made. That is unless you want to change the compression and do internals.
Old May 27, 2005 | 02:55 PM
bwzabodyn's Avatar
bwzabodyn
n/a modding sucks, period... I've spent well over $4k, and even though I saw decent results after every mod (I went from 218whp to 252whp before header install - I'm probably right at 260) - I wouldn't do it all over again the same way...
the only things I WOULDN'T change would be the 3.53 rear end/lsd swap and the Injen Exhaust...
Old May 27, 2005 | 06:21 PM
Damian's Avatar
Damian
4K to spend on upgrades is one thing but you guys are forgetting instalation fees = $$$.
Old May 27, 2005 | 08:29 PM
Armitage's Avatar
Armitage
^Stuff like intake, exhaust, pipes, etc. you can do yourself. But flywheel/clutch, etc. your correct.
Old May 28, 2005 | 12:57 AM
themartyr's Avatar
themartyr
thanks for replies. its 4k on parts, installation i can worry about. NA is a ***** wth these cars i know but thats probably all im going to put into the car besides some cosmetic things. So what would be the better way to go, bolt on mods or the final drive etc. way? keeping in mind that im probably only going to do one or the other! Thanks again
Old May 28, 2005 | 03:51 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Test/Cat Pipes $500
This is great advice! DO it!!!!
Old May 28, 2005 | 06:43 PM
themartyr's Avatar
themartyr
Test/Cat Pipes $500
im thinking of doing this with the stage 4 AAM deal. Hows that sound? actually stage 3 because my dad knows a guy that reprograms cars. He does computer work for Nascar!
Old May 28, 2005 | 10:09 PM
GTO2350's Avatar
GTO2350
your car will feel alot more faster with the tilton clutch/flywheel & 350evo 3.9final drive than the AAM stage 3 you gotta factor in install tilton and 3.9fd intall will be around 1100 for both so thats about 3100 spent on parts and labor for tilton and 3.9 final drive how much is the stage 3 AAM??
Old May 28, 2005 | 10:42 PM
themartyr's Avatar
themartyr
Im want to do both. the final drive etc. and the stage 3. the stage 3 is $879! its a little over my price but im in no hurry. im curious to how my car is going to be with both of these!
Old May 29, 2005 | 01:18 AM
dan-14's Avatar
dan-14
sorry,newb questions-
what will the ATS Carbon LSD do?
does it have any drawbacks?
Old May 29, 2005 | 01:57 PM
Z33Concept's Avatar
Z33Concept
Save For A Custom Turbo Along With An Engine Rebuilt
Old May 29, 2005 | 02:21 PM
themartyr's Avatar
themartyr
That cost way too much. i would never put that much into this car. i would go finance a vette before i put like 15000 dollars into a 24000 car
Old Jun 9, 2005 | 03:43 PM
UsafaRice's Avatar
UsafaRice
... but it would just be a stock Vette ...
Old Jun 9, 2005 | 04:47 PM
TwiZted's Avatar
TwiZted
My 350EVO 3.9 FD cost $1650 all said and done labor and parts. In all honesty the flywheel would be great but why not just do that when the stock clutch needs replacement. Get UR Pulleys ~$300, Exhaust ~$1000(installed), High Flow Cats ~$500, Headers $700(installed) Add in the FD and your looking at $4150 for everything, figure you can do the installs on some of the easier parts or if your a good enough garage mechanic (not me!) you could save $300 bucks and do the header install yourself. You should see damn near 250-255rwhp paired with the 3.9 FD your car will be a whole new beast.
heres a link to my final drive review: http://chicagoz.com/v-web/bulletin/b...pic.php?t=1617
If your staying N/A I strongly suggest this mod. I lost to an 03' Carrera 4s by 2 car lengths from 0-125mph ( the 4s quarter mile time is 13.1), My car is lightly modded in terms of power adders, the gear makes a huge difference!
Detailed Image
Cleaning & Detailing
Nov 26, 2021 01:05 PM
Workshop12
Mar 23, 2020 01:45 PM
Detailed Image
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
Detailed Image
Sep 8, 2015 10:41 AM
